This function periodically changes the state or on the OVR, or on the INS, it is sometimes not observed INS = INSERT, and it happens that instead of INS = OVERRIDE. There is no regularity.
I found a solution - just set English interface, not Russian. For me it works.
ok i found consistent pattern
when changing window from file to file printing type is set to OVR everytime and can be still "INV" string
Any chance you're hitting the Insert key on your keyboard?
On mine, it's right next to Home and Delete keys which I frequently use.
Nancy
Absolutely not.
P.S. with Ctrl+E shortcut same thing
me too
Can you try restoring preferences and let us know o if it helped?
Unusual behavior in Dreamweaver? Try restoring preferences.
Preran
I've done it. Furthermore, I completely uninstalled all Adobe applications and set them again. But that's not all, I completely formatted the hard drive, remove and install from scratch the operating system. Two Mac (iMac and MacBook Pro). Nothing helped.
That's strange. Send me your Adobe ID, location, and phone number over a private message. Click my picture and use the Message button. We will get in touch with you for investigation.
Preran
Read all instructions on the ADOBE website, several times I uninstalled and again installed all ADOBE applications. Nothing helps. Now I'm using DreamWeaver 2015
how to change Russian interface to English?
Just reinstall it, easiest way
To change a program's language...
1. Uninstall the program
2. Open the CC Desktop App and click the gear icon in the upper right
3. Click Preferences
4. Click Creative Cloud
5. Choose English from the App Language dropdown menu
6. Click the back arrow in the upper left
7. Click the Apps tab
8. Install the program
ок, thanks
That is, this error occurs only in Russian? So it's discrimination!
