PE14.1 on a WIN7 PC...
Sometime at the end of a video I add a number of photos (also using pan-and-zoom).
After last video clip & before first photo I have often inserted a Graphic (Miscellaneous)
called Road_Map into the timeline and placed a title text over this on video 2.
This has worked fine on HD videos - now I've gone back to edit some pretty old (2012!) .avi videos.
However, when I insert the same graphic into the time line I only see a small portion rather than the whole graphic as I did on the HD video:
I assume this has to do with the lower resolution of this non-HD video. The Frame Size of the project is 720 by 576.
I have not been able to find a way to shrink the graphic - is there a way?
Hi Howard,
Thanks for asking question on this forum.
Please check this link: How to use Motion effect in Adobe Premiere Elements
This would help you out.
Sandeep
Actually in this particular case the solution is simpler...
Because I had been working with Pan and Zoom I had turned off "Default scale to frame size" in Preferences / General.
Which meant that the Road_Map was also inserted unscaled.
The simple solution is to select the clip with the Road_Map, RMB & in the popup select Clip / Scale to Frame Size.
