Dear friends and experts!
To avoid one (or more) of the special effects reported in this forum Klaus Göbel proposes to unregister the script when it is closed. But: when is the script closed?
I did not get a formal education in interactive programming, hence I have no real clue about the process: what is calling what. My programming experience is in procedural languages starting with Fortran in the 1960ies.
Please point me to a document describing all this - the Scripting Guide does not tell. And of course JavaScript books don't either.
The only sample script using Notify is FM_Suppress_Alerts.jsx and this is absolutely simplistic.
My understanding is this:
The main structure of my script is this:
// --- Windows ID must be set outside the dialogue function to be available for Notify functions
var wPalC = new Window("palette","FM-calc : Handle #calc Markers", undefined);
//... also wPalS and wPalDSmain ();
function main () {
SetUpGlobals (); // all global variables and constants
SetupFMcalc (); // get inital data -- debug to be set explicitly
SetupNotifications (); // notification trigger 'Change document' etc.
// --- During development switch between the two following statements:
SetUpMenus(); // uncomment for real work
//DebugMenu (); // comment for real work - debugging does not work with menus
#include funGlobals.jsx
//... more includes
function SetUpMenus () {
function Command (cmd) {
function SetupNotifications () {
function RemoveMyNotification() {
function Notify (note, object, sparam, iparam) {
//--- now follow the functions directly called from Command
function OpenHelpFile ()
function DoFMcalcInSelection()
function DoFMcalcInDoc ()
function DoFMcalcInBook ()
function HandleCalcMarkers()
function HandleSeriesMarkers()
function HandleDocSettings()
//...And all the others which I want to have in this module
In the past I had the call of RemoveMyNotification in the call-back functions for the Cancel/Exit buttons in the panels. But now I guess that the best place would be at the end of the Command function: After anything has been done.
But: SetUpNotifications is within the main function and will not be executed anymore after the script has been started the first time.
I need a better insight, sigh!
Hi Klaus,
I don't know if I understand your question correctly, but I'll give it a try.
FM loads a script, when it is registered or when it is in a startup Folder (user dir, inst dir). This script is never unloaded. It is always there, as well as its global variables. Only a function finishes, when its job is done.
Your main function is called when the script is loaded by FM, or better by the ExtendScript plugin (fminit\FrameMakerScriptingSupport.dll). So your notifications are registered when FM is started, and they stay registered as long they are unregistered (Notification(YOURNOTIFACATIONOFINTEREST, false)).
So if you don't want to be notified again, you have to call that function somewhere in your code, perhabs when any function ends. Lets say you have a checked menu (true/false), which enables or disables an Event handler, so put the code in there.
I don't understand, why it makes sense to deactivate a notification after a command is executed. But if you Need this in your Special use case, call this at the end of the command event handler (Command(cmd)). Then FM get back the Control and this function is finished.
Of if you don't Need it any more, after an Event is called the first time, unhook it at the end of the notify eventhandler (Notify (note, object, sparam, iparam)).
Markus
Hi Klaus,
one recommendation. Write one script for each use case you want to solve:
If you want to make a reuse of some functions, put these in some separate jsx-files and include them, where they are needed.
In this case your notification (watch dog) script is very simple.
#include "something.jsx"
Notification(YOURNOTIFACATIONOFINTEREST, true)
switch(note)
case YOURNOTIFACATIONOFINTEREST;
DoSomething() ;
break;
Put this script to your startup folder and the commands also. This is easier to maintain, then registering anything in one single script.
Hi Klaus,
here some scripts:
EventTest1
alert ("Start TEST1","TEST1");
TestString = "First";
w1 = new Window("palette","My First Test",undefined);
CloseButton = w1.add ("button",undefined,"close",{name:"cancel"})
w1.show();
CloseButton.onClick = function(){w1.close()};
Notification(Constants.FA_Note_PostMouseCommand,true);
w1.onClose=GoodBye;
function Notify(note, object)
switch (note)
case Constants.FA_Note_PostMouseCommand:
alert("TEST1: " + TestString,"TEST1");
break;
function GoodBye()
alert("BYE1","TEST1");
Notification(Constants.FA_Note_PostMouseCommand,false);
EventTest2
alert ("Start TEST2","TEST2 ");
TestString = "Second";
w2 = new Window("palette","My Second Test",undefined);
CloseButton = w2.add ("button",undefined,"close",{name:"cancel"})
w2.show();
CloseButton.onClick = function(){w2.close()};
w2.onClose=function(){alert("BYE2","TEST2")};
switch (note)
alert("TEST2: " + TestString,"TEST2: ");
break;
EventTest3
alert ("Start TEST3","TEST3");
TestString = "Third";
w3 = new Window("palette","My Third Test",undefined);
CloseButton = w3.add ("button",undefined,"close",{name:"cancel"})
w3.show();
CloseButton.onClick = function(){w3.close()};
w3.onClose=function(){alert("BYE3","TEST3")};
switch (note)
alert("TEST3: " + TestString,"TEST3");
break;
Testsequence:
- Open any document.
- Start EventTest3 first, then EventTest2 and then EventTest1
DON'T CLOSE THEM YET, only click OK.
You can see these scripts in your scriptlibrary (radiobutton registered) ordered like this:
EventTest3
EventTest2
EventTest1
Because the dialogues are overlapping, move them.
Click into the document at any place:
Now you can see the alerts :
- TEST3: First
- TEST2: First
- TEST1: First
Now close all dialogs
- TEST3: First
- TEST2: First
"TEST1: First" is missing, because it is unregistered
Have a look at the value of the variable "TestString" (First)
Now restart FrameMaker and open any document.
You can see in your scriptlibrary (radiobutton registered) registered scripts ordered like this:
EventTest2
EventTest3
And when clicking into the document you'll get the order:
TEST2: Third
TEST3: Third
because it now is in alphabetical order.
If you NOW change EventTest2:
to
alert("New TEST2: " + TestString,"TEST2: ");
you can see, that this is displayed.
Means: if you have a real script where lots of things happen and you change the script (while it is still registered) this function is called and can cause what cou call "special effects"
and of course: after the test you have to remove the registered scripts manually
That demonstrates the danger within registering / not unregistering scripts and and also the usage of global variables.
I hope, that helps to understand these things a little better.
I also hope this does NOT lead to additional confusion.
