I had a project I made in Flash CS6, and have opened it in Animate and resaved it as a new file. I am now trying to edit the publish setting for the file. The publishing setting dialogue box opens, but I cannot change anything settings. Any advice?
what are you trying to change?
I was trying to change the format and the output name. Nothing seems to be selectable or editable.
from your screenshot it looks like you can change the output name. what happens when you click into that field?
It will not select anything...it will not allow me to select anything or change anything...It's almost like the page is frozen, but it's not.
create a new directory and save the fla to that directory with a new name.
then open your publish settings panel and see if you can change anything.
