I am trying to move an object from point A to point B, however, I keep running into this problem where my object makes additional movements in between key frames. I never turned on easing and am using standard linear key frames. Why does this keep happening?
Here is a shot of the graph editor, which illustrates the extra movement that I cant eliminate,
select the two keyframes then right click
choose keyframe interpolation
spatial Interpolation
change it from Auto Bezier to Linear
we call it "the boomerang effect". learn about it here:
to avoid these kinds of problems, set you preferences default spatial interpolation to linear checkbox to ON
Awesome, thanks!
Looks like this did the trick, thanks.
