Table cells will not line up horizontally where cells are merged
Dec 01, 2016 Dec 01, 2016
I have a large table with many merged vertical cells. When merging them, they do not line up horizontally with the cells to the left or right of them. At most, I am only merging two vertical cells. I've tried everything in the settings, and dragging the cells does not work. I'm beginnig to think that lining them up will not be possible when merging.
2.9K
Community Expert , Dec 02, 2016 Dec 02, 2016
You can set cell height in Table > Cell Options > Rows and Columns. Change the Row Height from At Least to Exactly.
Mentor ,
What You encounter is normal behavior.
Cell Options > Text > Vertical Justification > Justify Vertically applied to all cells might help in some cases like this:
but if you want real and robust horizontal alignment, Baseline Grid is your friend...
for what it worth, in this case it would have more cons than pros, imho...
I tried this, and it spreads out the type some, but the cells are still not aligned horizontally. Any other ideas? Not sure why this happened only in 3 cases, but it really stands out as a big mistake. Thanks!
Would you be willing to share a screen shot of the table? Baseline alignment controls vertical alignment, and you are asking for horizontal alignment, so I'm confused. You can use the button shown below to add the screen shot to your reply.
HI - Here'sScreen Shot 2016-12-02 at 10.12.33 AM.png a screenshot - you'll see it happening in the middle 3 columns. Thanks!
Mentor ,
hm... these cells itself are of different height (why?), so what do you expect?
Look at the green sections that are together. They are different heights and shouldn't be. And it's happening in other places.
Mentor ,
Yeah, this is exactly what I was asking... Why they are different? It depends on how this table was build and edited. Only you can say this having the 'live thing' before your eyes . And there could be different ways to correct this.
That was your problem, not the text...
Edit: ah, vinny tries telepathy
Got it to work by nudging the numbers. When I put in the exact height of the cell next door whose height I wanted to match, it didn't match -- but by playing around with the number, I got it to visually match. I can live with this, thanks for your help!
Dec 03, 2016 Dec 03, 2016
what happened while you are doing the old version of your table is that you added rows while splitting a cell.
Spltting cells always adding rows (or columns).
When doing complex tables where are lot of cells should be merged or later be splitted, I usually start out with a basic grid like that:
Note the green colored row and column.
I'll keep this construct until the table is finished.
Now, you merge the necessary cells to layout your table and maybe remove a column, but never remove the green colored ones:
Note, that you can always copy/paste a bunch of cells to an already merged area:
On the other hand you could also copy/paste merged cells:
That would help you to quickly build a complex table, I think.
The trick is to keep the basic column and the basic row colored green in my example.
Uwe
Another note on my last post:
1. You can do a duplicate of the base grid and work on the duplicate.
2. Before doing the work you could do some base "bricks" so to say by merging some cell areas before and copy/paste them all around in your duplicated table base grid:
Uwe
Guide ,
Hi
I bet you first merged cells, then used split cells instead of cancel merging.
Have a look at this:
You are correct!!
I just figured this out on my own a few minutes ago, so I'm glad you concur. I will know better next time. Thanks for your help.!
