I'm building a new PC for video editing and I am considering this arrangement for storage:
Samsung 960 PRO NVME M.2 512GB: O/S and Programs
Samsung 850 PRO SATA 2TB: Data, Media/Projects
Western Digital Red Pro 7200 HDD 8TB: Mass Storage and Previews/Exports
Western Digital Red Pro 7200 HDD 8TB: Backup and Media Cache
Or would I be better off with Previews/Exports and Media Cache placed on the 850 PRO along with Media/Projects?
During the Golden Days of HDD's, we usually split these off onto separate drives. But with SSD's, I'm not so sure. Can the SSD really handle all those tasks better?
Remaining components are 32GB RAM, I7-7700K CPU, Z270 Motherboard, GTX-1080 GPU, Enermax 750 Platinum PSU.
Yes, SSDs are really quite a bit better. You'll be best off to put all the cache, scratch, and previews on the 960 Pro boot drive which is by far the fastest drive. And I would think that 512GB would be enough to handle all these files in addition to your OS and programs.
You can pretty much send the exports wherever you'd like.
Jim
OK, thanks. If I can have only one PCI-e based SSD in my system, would it make more sense to use a smaller SATA drive for the O/S and programs exclusively and increase the size of the NVME SSD, as follows:
Samsung 850 PRO SATA 512GB: O/S and Programs
Samsung 960 PRO NVME M.2 1TB: Data, Media/Projects, Cache, Previews
Western Digital Red Pro 7200 HDD 8TB: Mass Storage and Exports
yes, exactly!
Jim
Is that because the O/S and programs are mostly read functions?
Also, another thread said to place media cache on the boot drive in a similar setup. Does that make sense.
Not really; it's more due to the fact that once the OS and programs have been loaded, they are largely RAM (memory) resident and don't need to read or write to the disk any more. Of course there is still some disk activity (on OS/programs drive), but nothing like the disk I/O going on with the bulk of the Premiere Pro files (media, scratch, cache, renders, etc.).
Great information. Really appreciate it.
Would it still be advisable to place the media cache on the O/S drive, like some people on this forum do?
Lastly, what is the difference between scratch and media cache?
M.2 and PCIe drives are about 3 to 4 times faster (or even more) than a fast single SSD. So in your case I suggested putting most the files on your M.2 drive.
Personally, I do put my cache/scratch files on my boot drive, but it's a PCIe SSD. My data drive is faster for total throughput (8x SATA SSD array), however my PCIe drive (and M.2 drives) has very little overhead and work well with multiple small files.
Here's a pretty good link for the full details of Premiere Pro file, including scratch and media:
Premiere Pro CC: Media Management Q&A | Larry Jordan
But really all you need to know is Premiere Pro creates and uses them for performance reasons and you can always delete them all and not loose anything that cannot be easily re-created. So, if you point them all to be stored in the same folder you know you can always get away with deleting them and you don't need worry about backing them up.
Jim
