Audio Spectrum Help?!
Dec 03, 2016 Dec 03, 2016
So, I have been using this spectrum for a while. I put it to the test using BASS boosted music. Then the problem occurred. The spectrum seems to have been cut off, and squared off, not like it should be. When the song is changed, with less BASS, or when I lower the maximum height, the problem does not happen.
AS YOU CAN SEE, RIGHT BELOW (1st Image), HAS THE SAME SONG, DIFFERENT HEIGHT. RIGHT UNDER THAT (2nd Image), IS THE SAME SONG, WITH MY DESIRED HEIGHT. SOMEONE HELP ME PLEASE. WHAT MIGHT BE THE PROBLEM?Bass Boosted Triboss, different height.JPGWith Bass Boosted Triboss.JPG
1.1K
Dec 04, 2016 Dec 04, 2016
Adjust the frequency range. Other than that it's of course possible that you screwed the audio file when you boosted the bass and caused some frequency bands to disapper. Impossible to be more specific without seeing your waveforms and effect settings.
Mylenium
Well, I know for sure it's not the song, cause I downloaded it. Here are the Effect Settings of the Spectrums. And forgive me for being stupid, but where would I change the frequency range? Cant seem to find it?Effect Settings for 2.JPGEffect Settings for 1.JPG
Dec 05, 2016 Dec 05, 2016
there is a different solution
instead using Polar Coordinates effect
draw a circle mask on the spectrum layer then use these settings
Then transform the circle itself, not the whole layer
Adobe Employee ,
Jan 17, 2017 Jan 17, 2017
Hi Serenityy,
Have you solved your issue yet?
Kevin
