I am trying to build a photo from one snapshot. It is a group picture of several heads. When I attempt to merge the three individual photos created from the cropping of the original the merge feature doesn't work for me? Live in the Forums: Ask an Expert
So are you trying to rearrange parts of the image?
Thank you for your help. This worked. I appreciate it.
David
For the merge to work there needs to be significant overlap between the images so Lightroom can figure out where to merge. If there is not enough overlap it won't work.
I read about cropping sufficient overlap in a previous post to the forum.
I tried creating more overlap twice now without success. Is there
something else I might try?
David
(Personal and business contact information is not allowed in the forums. Turn off your signature file--Moderator)
Wait. Third time is a charm. I has worked. Thank you. I will follow up
in the forum as requested.
I appreciate it!
David
Very good. Your response helped. My question is answered and problem solved. thank you
