Is it possible to create seperate dangle points strenghs?
For example. I have a character with dangle points on his hair, and on his tie. I want the gravity effect, etc, to be different on the hair from the tie, is this possible, and if so, how?
Thank you
Scott
If you select a subpuppet group in the puppet panel, and click the "+" sign under behaviors over to the right side of the panel, you can add a behavior just for that group. Dangle works well, but I'm not sure how well Face will work on a subpuppet.
It would also be handy to independently adjust the strengths on other elements, such as parallax. You may want one part to move more flexibly than another.
Also, how do I enlarge the artboard?
Ah, thanks KJerry, that seems to have done the trick
Any chance you know how to enlarge the artboard area? My character was sized for a 1920 x 1080 screen, so the board in the sample above must be pretty small, so I dont wanna size him down
In the scene, deselect the puppet, Then over to the right you can adjust the width and height, along with duration and frame rate.
Thanks again
