when I open a PDF there comes the error "Namensobjekt wurde erwartet".
This notification doesn't disappear and I have to close the program with the task manager.
I edited the PDF earlier with AppleĀ“s preview..
Somebody an idea?
Hi Lukasr94171861,
You may try the repair installation of the application and check the same.
If it still happens, please confirm the OS and application versions you are using.
Also, please confirm if its happening with all the files and if its a praticular file, share it with me so i can check the same at my end.
Supriya
thanks for your answer. I reinstalled the program now on my MacBook, but the error is still there.
But itĀ“s interesting: the program only crashes with on document...
Regards
Don't use Preview of Apple.
sometimes itĀ“s better to use preview because it runs smoother on my Mac.
@sb116: I found a few more documents that caused a crash of the Adobe Reader...
Use preview when you will get corrupted PDF files.
