I just started using CC, and one thing I'm noticing is that a rotated vector link is not displaying properly. It displays properly when at zero degrees, and PDF exports are fine. Here's a visual ...
What version of InDesign and OS are you running?
2017.0 (12.0.0.81)
Mac OS 10.12.1
Moving to InDesign​
is your vector link outlined text or live fonts?
Outlined; no fonts involved.
Hi Jeff,
what kind of file type is the linked vector graphic?
What is the creator app?
Uwe
The linked vector is an .ai file (CS6). My workaround was to just paste the vectors directly into the InDesign doc, which displays fine, but just curious why the display is getting wacked out, or at least let folks know about the possible bug.
Let the developers know about a possible redraw bug:
Provide a link to sample material on a download service like Dropbox.
If you like, post the link here so that we can do a test as well.
Uwe
I was wondering if it was outlined because at first glance, it appeared like the snap to pixel grid option had somehow activated in the linked file preview. I would expect to see this kind of transformation glitch in Illustrator natively, not in a linked preview in InDesign.
Do you have any Effects on this text?
Sorry, haven't had a chance to get files up. No effects, just plain vectors. Only the curved portions are affected. One interesting thing: when rotated at any angle other than -90Ëš (-89.9 or -90.1 or +90Ëš for instance) it displays fine (and every once in a while it will display -90Ëš OK). I'm getting the same result with other vectors as well. And if I set up a new InDesign file, it doesn't seem to happen. But with other InDesign files that are, or were formerly, CS6 InDesign files, it does it with other vectors, even brand-new ones ... so it seems so far, for me anyway, that InDesign files with some CS6 DNA do not like to display curved vectors properly when rotated at precisely -90Ëš (most of the time).
Do you have anti-aliasing turned on?
Yes, anti-aliasing is enabled.
