So this is my first time using Muse. It is for my graphic design class. This has occurred on different three occasions now with this project. I can type normally when I first open the document. After a short span of time I can still type until Muse will slow down and I will still be able to type but I lose the ability to delete the text at all. Anyone have the same problem? If so, how did you fit it without restarting the program?
Hello,
I would advise you to check following:
If you are on Windows machine then go to this path - C:\Users\<user name>\AppData\Roaming
let me know if the issue still persist.
Ankush
