Hello, when I open InDesign I get the new Start Workspace which I like and do not want to turn off. The problem is that there are many documents there which I've moved/deleted and I want to clean it up so only documents that exist and are pertinent appear. Is there a way to do this?
I think you will have to clear the list and rebuild it.
But wouldn't it be great to be able to right click a file in the Start Workspace and be able to choose something like "Remove from Recent File"? You can add feature requests here: Wishform - Adobe InDesign.
Barb, thanks for this. Can you tell me how to clear the list?
I figured out how to clear the list. I went to Preferences | File Handling and set the number of recents to 0, then reset it to 5. That cleared the list which is as good a workaround as any. I also put in a feature request as you suggested. Thanks for your help!
Preferences | File Handling and set the number of recents to 0, then reset it...
That was going to be my answer!
You can turn the option off in the Preference > General. It's the first box option.
