Hey Guys,
Why are my files exported with AME 4 times bigger then the ones exported with after effects using the exact settings and codecs?
for example
2 second Comp 1080i DNxHD 120 8bit is 40mb exported in After Effects
the same Comp rendered in AMe:
2 second Comp 1080i DNxHD 120 8bit is 181mb
Audio,export and render settings are the same?
How can this be possible?
Greetings from Cologne
Could you show us screenshots of your render/export settings in both apps?
Also, what, exact, version number of each app are you using?
I bet the Bit Rate setting is higher in AME.
Hi Rechner 4H,
Did you solve your problem yet? Let us know any details, please.
Kevin
