I have a white logo and want to export it to PDF. Unless I create a non printable dark background this will not be visible on the white background.
I have come across some files like this, where the white object had like a keyline preview to make it visible on screen. Is there a quick option to choose this view mode when exporting or do I have to create a non printable stroke?
If you produce this PDF with a non-printing dark background or stroke, what is the purpose of the PDF of the white logo?
I'd guess that the OP wants the white artwork saved as a PDF that he can place elsewhere against a dark background of their choice.
Are you concerned about seeing it in InDesign or in Acrobat? And did the logo originate in Illustrator?
It seems a bizarre way of working!
I've worked with files that like... they are white, and intended to be placed on a dark background. That said, only directly out of Illustrator where they can be seen, and edited, in Outline view. I've never seen a transparent logo designed in InDesign. Or any logo, really, designed in InDesign.
If it's being designed in InDesign, one can redefine the default white paper to a dark color, and it won't impact the printing or the PDF.
Some files are very basic and created in inDesign, and as you pointed out Barb, they need to be placed by the client on a dark background, like a T-shirt for example. Unfortunately not all my clients have Illustrator.
I used to create a separate layer as a dark background, which after exporting to PDF I set to a non printing layer.
I was hoping for something like an outline view in a PDF, but it looks like I just have to do it the hard way.
Thanks for your thoughts though.
Why not supply it as a PNG with transparency?
Portable network graphics are suitable for web and dare I say for general office use, but I would never replace a vector based PDF with a PNG, especially if clients intend to up-scale the image.
If you have Illustrator, if you know it, and if you are the one creating the logos (that's a lot of "ifs!", you could create a PDF right out of Illustrator. The clients wouldn't ned to know how to use it, or even have it.
