Hello,
I have 200 PDF files that are location specific (all different). I need to add a unique page (A map) into each document. I know with the Action Wizard I can insert a set of pages into ALL of the documents, but I need a different page in each different document. Can this be done? These will be updated from time to time and I'd rather not do them manually each time.
Is there some kind of logic behind which page should be inserted in each file?
The file name of the page would be similar to the file name of the document, and in the same order (I.E. map 1 goes to document 1, map 2 goes to document 2). I could even add unique numbers to each file name if that would help solve the problem.
In that case it should be possible, but it would require a custom-made script. You would also need Acrobat Pro to run this script, as a part of an Action.
If you're interested I could develop this script for you and help you set it up, for a small fee. You can contact me at try6767 at gmail.com to discuss it further.
