1
turn off hyphenation throughout a document
Enthusiast ,
Sep 18, 2008 Sep 18, 2008
Is there a checkbox that will turn OFF hyphenation throughout a whole document, or an easy way to disable hyphenation?
How to , Type
228.9K
Advocate , Sep 18, 2008 Sep 18, 2008
CS/CS2
For NEW documents:
With no documents open, go to your paragraph palette/panel. From the palette menu, select Hyphenation. Deselect the option box.
If you have any paragraph styles pre-defined, be sure to change the setting within them, too.
This sets your default for all new documents.
For EXISTING documents:
You can change the hyphenation option for all new text frames by repeating the step above with a file open and nothing selected. This will not alter existing frames.
Next, ...
Advocate ,
CS/CS2
For NEW documents:
Next, edit all your paragraph styles, to change the hyphenation option, if you use them. This will alter all paragraphs using the paragraph styles.
Finally, select all text frames and repeat the steps above.
Other:
Find someone to script it for your (if it hasn't already been done).
HTH
-mt
Guru ,
Michael's given an excellent rundown of the options.
But here's something that has blown me away.
Why isn't there an option in Find/Change to turn off hyphenation? And along the same lines, what about justification?
Enthusiast ,
Sep 21, 2008 Sep 21, 2008
Michael, Thanks for your thorough summary of the options. I understand that QuarkXPress has an option to globally turn off hyphenation, but don't know for sure as I'm not an XPress user. I was hoping that InDesign had something similar.
Jan 29, 2015 Jan 29, 2015
Yes, Quark does have an easy as pie way to turn off Hyphenation. Under the Edit menu, select H&Js (hyphenation and justifications) then double click on No Hyphenation. This will open a window that shows the current settings for No Hyphenation. If the Auto Hyphenation box is already Unchecked, just click OK or press Enter. If there's a check in the AH box, just uncheck and click OK.
Now click the Save button and you're all set. Easy peasy. This is just one of the many many reasons I prefer Quark over ID. But that's me.
Because I use styles, I don't have any real need for these in find/change. However, a feature that Corel Ventura has would be useful. In that app, you can select multiple styles and change properties for all of them at once. For example, I could select all paragraph styles and turn off hyphenation in them all at once.
Enthusiast ,
Well, you CAN search and change justification if you want. Leave the find and change boxes blank. Under "Find Format" choose Indents and Spacing, select the justification you want to find, and under "Change Format" select the justification you want to change it to.
But using Paragraph Styles is a much better way to do this. If all of your running text is based on your Body style, just redefine the Body style, and you won't mess with your headings, tables, and figure legends, and anything that isn't running text. And, with style definitions, you can change hyphenation options globally.
Rodney
Yes, but I assumed Sandee was referring to all the options under the Hyphenation and Justification tabs. The find/change has most of the other tabs you find under paragraph styles, but not all.
Mentor ,
Sep 22, 2008 Sep 22, 2008
FrameMaker has this abilty too, though it lacks based-on styles.
Peter Gold
KnowHow ProServices
InDesign can do it too! ;)
app.documents[0].stories.everyItem().hyphenation=false;
Harbs
http://www.in-tools.com
"Automated Publishing for the Rest of Us!"
Guest
Dec 05, 2013 Dec 05, 2013
I try the script, but doesn't work in table, how can also turn off hyphenation in table's text with javascript?
Dec 06, 2013 Dec 06, 2013
@creativejoan0425 – As you can see tables have to be accessed separatly.
Also footnotes.
The following script handles also footnotes and tables (but not tables inside tables!):
//TurnHyphenationOFF_Stories_Footnotes_PlainTables.jsx
//Uwe Laubender
//DESCRIPTION:Does NOT work for TABLES INSIDE tables!
//See discussion at:
//http://forums.adobe.com/thread/323599?tstart=0
* @@@BUILDINFO@@@ TurnHyphenationOFF_Stories_Footnotes_PlainTables.jsx !Version! Fri Dec 06 2013 11:24:16 GMT+0100
app.scriptPreferences.userInteractionLevel = UserInteractionLevels.interactWithAll;
app.doScript(_TurnHyphenationOff, ScriptLanguage.JAVASCRIPT, [], UndoModes.ENTIRE_SCRIPT, "Turn off hyphenation");
alert("Done: Hyphenation is off for all stories, footnotes and plain, not nested tables.");
function _TurnHyphenationOff(){
var everyStory = app.documents[0].stories.everyItem();
//Plain stories:
everyStory.texts[0].hyphenation = false;
//All footnotes:
everyStory.footnotes.everyItem().texts[0].hyphenation = false;
//Plain table cells (NOT NESTED TABLES):
everyStory.tables.everyItem().cells.everyItem().texts[0].hyphenation = false;
}; //END function _TurnHyphenationOff()
You can undo the script in one go…
Uwe
Guest
If I want to do it in a selection? I want to select a table row to turn off hyphenation, how can I do?
從三星手機發送
Do it manually -- select the text in the row, choose Hyphenation from the Control panel flyout menu, and clear the checkbox.
That would be:
app.selection[0].cells.everyItem().texts[0].hyphenation = false;
Uwe
Guest
It doesnt work
從三星手機發送
With a table row selected, it will work. I tested that…
Or did you ask how to select or adress a table row to turn hyphenation off? If yes, which one?
For a table put into the variable myTable, for the first row of that table it would be:
myTable.rows[0].cells.everyItem().texts[0].hyphenation = false;
The variable myTable can stand for any table in a document.
To make myTable the first table in a specific story, select a text frame of that story and:
myTable = app.selection[0].parentStory.tables[0];
Uwe
Guest
Here is my script, I use the Adobe FindChangebyList to make some modified, I want to clear the hyphenation and break link to style when I select texts or table row, or maybe a cells, can you help me to fix the error? thx ver much
main();
function main(){
var myObject;
//var myCheckSelection = false;
//Make certain that user interaction (display of dialogs, etc.) is turned on.
if(app.documents.length > 0){
  if(app.selection.length > 0){
   switch(app.selection[0].constructor.name){
    case "InsertionPoint":
    case "Character":
    case "Word":
    case "TextStyleRange":
    case "Line":
    case "Paragraph":
    case "TextColumn":
    case "TextFrame":
                  case "Text":
    case "Cell":
    case "Column":
    case "Row":
    case "Table":
     myDisplayDialog();
     break;
    default:
     //Something was selected, but it wasn't a text object, so search the document.
     //myFindChangeByList(app.documents.item(0));
                    //alert("Nothing Selected, Please Select Text Frame or Text.");
  else{
   //Nothing was selected, so simply search the document.
else{
  alert("No documents are open. Please open a document and try again.");
function myDisplayDialog(){
var myObject;
var myDialog = app.dialogs.add({name:"Joan New Clear Setting_v1.0"});
with(myDialog.dialogColumns.add()){
   with(dialogRows.add()){
   with(dialogColumns.add()){
staticTexts.add({staticLabel:"Search Range:"});
     var mySearchButtons = radiobuttonGroups.add();
     with(mySearchButtons){
     radiobuttonControls.add({staticLabel:"Current Document", checkedState:true});
                   if(app.selection[0].contents != ""){
    radiobuttonControls.add({staticLabel:"Selection", checkedState:true});
    with(borderPanels.add()){
     staticTexts.add({staticLabel:"Clear Setting:"});
     var myDateButtons = radiobuttonGroups.add();
     with(myDateButtons){
     radiobuttonControls.add({staticLabel:"English", checkedState:true});
     radiobuttonControls.add({staticLabel:"Chinese"});
var myResult = myDialog.show();
if(myResult == true){
  switch(mySearchButtons.selectedButton){
   case 0:
                 BreakLinktoStyleDocument();
                 TurnOffHyphenationDocument();
                 myObject = app.documents.item(0);
    break;
              case 1:
                 BreakLinktoStyleSelection();
                 TurnOffHyphenationSelection();
                 myObject = app.selection[0];
                 myCheckSelection = true;
    break;
  switch(myDateButtons.selectedButton){
  case 0:
  myFindChangeByList1(myObject, myCheckSelection);
  break;
  case 1:
  myFindChangeByList2(myObject, myCheckSelection);
  break;
  myDialog.destroy();
  //myFindChangeByList1(myObject);
else{
  myDialog.destroy();
function TurnOffHyphenationDocument() {
app.activeDocument.stories.everyItem().texts.everyItem().hyphenation=false;
myTables = app.activeDocument.stories.everyItem().tables.everyItem();
myTables.cells.everyItem().paragraphs.everyItem().hyphenation=false;
function TurnOffHyphenationSelection() {
app.selection[0].texts[0].hyphenation=false;
app.selection[0].cells.everyItem().texts[0].hyphenation=false;
function BreakLinktoStyleDocument() {
app.activeDocument.stories.everyItem().texts.everyItem().applyParagraphStyle(app.activeDocument.paragraphStyles.item(0), false);
app.activeDocument.stories.everyItem().texts.everyItem().applyCharacterStyle(app.activeDocument.characterStyles.item(0), false);
myTables.cells.everyItem().paragraphs.everyItem().applyParagraphStyle( app.activeDocument.paragraphStyles.item(0), false);
myTables.cells.everyItem().paragraphs.everyItem().applyCharacterStyle( app.activeDocument.characterStyles.item(0), false);
function BreakLinktoStyleSelection() {
app.selection[0].applyParagraphStyle(app.activeDocument.paragraphStyles.item(0), false);
app.selection[0].applyCharacterStyle(app.activeDocument.characterStyles.item(0), false);
app.selection[0].cells.everyItem().texts[0].applyParagraphStyle(app.activeDocument.paragraphStyles.item(0), false);
app.selection[0].cells.everyItem().texts[0].applyCharacterStyle(app.activeDocument.paragraphStyles.item(0), false);
function myFindChangeByList1(myObject, myCheckSelection){
var myScriptFileName, myFindChangeFile, myFindChangeFileName, myScriptFile, myResult;
var myFindChangeArray, myFindPreferences, myChangePreferences, myFindLimit;
var myStartCharacter, myEndCharacter;
var myFindChangeFile = myFindFile("/ScriptSupport/te.txt")
if(myFindChangeFile != null){
        // Because the selection will change as we add/remove characters,
        // we'll need to reset the selection after each pass if we are
        // checking the selection. We'll get the index of the first character
        // in the selection (relative to the start of its parent story) and
        // the index of the last character in the selection (relative to the
        // *end* of the story, and we'll use them later in the script to
        // keep the ends of the selection in place.
  if(myCheckSelection == true){
   var myStart = myObject.characters.item(0).index;
   var myEnd = myObject.characters.item(-1).index;
   var myStory = myObject.parentStory;
   var myStoryEnd = myStory.characters.item(-1).index;
   myEnd = (myStoryEnd - myEnd)+1;
  myFindChangeFile = File(myFindChangeFile);
  var myResult = myFindChangeFile.open("r", undefined, undefined);
   //Loop through the find/change operations.
   do{
    myLine = myFindChangeFile.readln();
    //Ignore comment lines and blank lines.
    if((myLine.substring(0,4)!="text")||(myLine.substring(0,4)!="grep")||(myLine.substring(0,5)!="glyph")){
     myFindChangeArray = myLine.split("\t");
     //The first field in the line is the findType string.
     myFindType = myFindChangeArray[0];
     //The second field in the line is the FindPreferences string.
     myFindPreferences = myFindChangeArray[1];
     //The second field in the line is the ChangePreferences string.
     myChangePreferences = myFindChangeArray[2];
     //The fourth field is the range--used only by text find/change.
     myFindChangeOptions = myFindChangeArray[3];
     switch(myFindType){
      case "text":
       myFindText(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions);
       break;
      case "grep":
       myFindGrep(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions);
       break;
      case "glyph":
       myFindGlyph(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions);
       break;
      myStartCharacter = myStory.characters.item(myStart);
      myEndCharacter = myStory.characters.item(-myEnd);
      myObject = myStory.texts.itemByRange(myStartCharacter, myEndCharacter);
      app.select (myObject);
   } while(myFindChangeFile.eof == false);
   myFindChangeFile.close();
alert("Done");
function myFindText(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions){
//Reset the find/change preferences before each search.
app.changeTextPreferences = NothingEnum.nothing;
app.findTextPreferences = NothingEnum.nothing;
app.findChangeTextOptions = NothingEnum.nothing;
var myString = "app.findTextPreferences.properties = "+ myFindPreferences + ";";
myString += "app.changeTextPreferences.properties = " + myChangePreferences + ";";
myString += "app.findChangeTextOptions.properties = " + myFindChangeOptions + ";";
app.doScript(myString, ScriptLanguage.javascript);
  myFoundItems = myObject.changeText();
//Reset the find/change preferences after each search.
function myFindGrep(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions){
//Reset the find/change grep preferences before each search.
app.changeGrepPreferences = NothingEnum.nothing;
app.findGrepPreferences = NothingEnum.nothing;
app.findChangeGrepOptions = NothingEnum.nothing;
var myString = "app.findGrepPreferences.properties = "+ myFindPreferences + ";";
myString += "app.changeGrepPreferences.properties = " + myChangePreferences + ";";
myString += "app.findChangeGrepOptions.properties = " + myFindChangeOptions + ";";
var myFoundItems = myObject.changeGrep();
//Reset the find/change grep preferences after each search.
function myFindGlyph(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions){
//Reset the find/change glyph preferences before each search.
app.changeGlyphPreferences = NothingEnum.nothing;
app.findGlyphPreferences = NothingEnum.nothing;
app.findChangeGlyphOptions = NothingEnum.nothing;
var myString = "app.findGlyphPreferences.properties = "+ myFindPreferences + ";";
myString += "app.changeGlyphPreferences.properties = " + myChangePreferences + ";";
myString += "app.findChangeGlyphOptions.properties = " + myFindChangeOptions + ";";
var myFoundItems = myObject.changeGlyph();
//Reset the find/change glyph preferences after each search.
function myFindFile(myFilePath){
var myScriptFile = myGetScriptPath();
var myScriptFile = File(myScriptFile);
var myScriptFolder = myScriptFile.path;
myFilePath = myScriptFolder + myFilePath;
if(File(myFilePath).exists == false){
  //Display a dialog.
  myFilePath = File.openDialog("Choose the file containing your find/change list");
return myFilePath;
function myGetScriptPath(){
try{
  myFile = app.activeScript;
catch(myError){
  myFile = myError.fileName;
return myFile;
and here is my text file (te.txt)
//001
grep {findWhat:"."} {appliedLanguage: app.languagesWithVendors.item("English: USA"), kerningMethod: "無"} {includeFootnotes:true, includeMasterPages:true, includeHiddenLayers:true, includeLockedStoriesForFind:true, widthSensitive:true}
//002
grep {findWhat:"."} {kinsokuSet: "繁體中文避頭尾(s)"} {includeFootnotes:true, includeMasterPages:true, includeHiddenLayers:true, includeLockedStoriesForFind:true, widthSensitive:true}
//003
grep {findWhat:"."} {mojikumi: "nothing"} {includeFootnotes:true, includeMasterPages:true, includeHiddenLayers:true, includeLockedStoriesForFind:true, widthSensitive:true}
//004
grep {findWhat:"."} {ligatures:false} {includeFootnotes:true, includeMasterPages:true, includeHiddenLayers:true, includeLockedStoriesForFind:true, widthSensitive:true}
//005
grep {findWhat:"."} {gridAlignment: 1852796517} {includeFootnotes:true, includeMasterPages:true, includeHiddenLayers:true, includeLockedStoriesForFind:true, widthSensitive:true}
//006
grep {findWhat:"."} {leadingModel: 1248619858} {includeFootnotes:true, includeMasterPages:true, includeHiddenLayers:true, includeLockedStoriesForFind:true, widthSensitive:true}
//007
grep {findWhat:"."} {characterAlignment: 1247896172} {includeFootnotes:true, includeMasterPages:true, includeHiddenLayers:true, includeLockedStoriesForFind:true, widthSensitive:true}
Dec 08, 2013 Dec 08, 2013
@creativejoan0425 – maybe it's best, to switch over to the InDesign Scripting Forum to discuss on.
http://forums.adobe.com/community/indesign/indesign_scripting?view=discussions
And another thing:
to present your code, there is the "Use advanced editor" button at the top right, if you are writing a new answer.
To format lines of code, select your code, go to the >> icon, click and chose: Syntax Highlighting/Java.
That's for better readability of your code.
Uwe
Guest
Dec 12, 2013 Dec 12, 2013
I just found when i run the script, that will not change in empty cell, how can i fix it?
從三星手機發送
What script exactly?
If it's something around:
myTable.cells.everyItem().texts[0].hyphenation = false;
it should work.
At least it's working for me.
Btw. what exact version of InDesign on what OS platform are you using?
A Chinese version? Maybe this is the culprit?
(Some bugs that are not present in the other international versions.)
Uwe
Guest
It ok, thx juust wrong typing of my script
從三星手機發送
Guest
Dec 13, 2013 Dec 13, 2013
Hi I also want to do in a selection to clear all linked style (Cell and Table Style), but found some error, would u mind to help me to fix it?
Thx a lots
BreakLinkToTableStyleSelection();
BreakLinkToCellStyleSelection();
function BreakLinkToTableStyleSelection(){
    var mySelection = app.selection[0];
    myTables = myDoc.tables.everyItem().getElements();
    for (var i=0; i<myTables.length; i++){
        myTable = myTables;
        myTable.appliedTableStyle = myDoc.tableStyles.item(0), false;
function BreakLinkToCellStyleSelection(){
    myCells = myDoc.cells.everyItem().texts[0].getElements();
    for (var i=0; i<myCells.length; i++){
        myCell = myCells;
        myCell.appliedCellStyle = myDoc.cellStyles.item(0), false;
Guest
Mar 19, 2014 Mar 19, 2014
Hi! I would like to reactivate this old thread.
Can anyone suggest a way how to modify the "TurnHyphenationOFF_Stories_Footnotes_PlainTables.jsx" script by Uwe so that it modifys tables and footnotes only if they are present in a document?
Actually the script does only work with documents witch do contains footnotes and tables.
This would be very helpful, thanks a lot in advance!
Guru ,
Sorry Rodney,
I wasn't clear.
I didn't mean paragraph alignment justification.
I meant the Justification controls as found in the Paragraph > Justification controls.
This doesn't make any sense that we can't search for all paragraphs with a certain justification Min or Maximum amound.
Or to search for all paragraphs set to hyphenation off.
I really don't understand this at all.
