How do I loop and fill pixel-by-pixel
Dec 08, 2016 Dec 08, 2016
Hello
I'm new to photoshop scripting so this might be a simple question to answer but after searching the internet for a couple of hours I thought I try out this forum.
I'm trying to create a white noise texture with 'perfect distribution', i.e. that each pixel/texel in a 16x16 bitmap has a unique grayscale value (0 to 255). So I was thinking maybe I could write a script using photoshop. For that to work I would need to get control of the pixel data, traverse it and fill each pixel individually.
Is this possible?
I did read that I could use Bridge SDK, Set each pixel randomly to one of five pre-defined colors . But that seems to be an old post aimed for CS6 and I'm using CC 2015 so I'm not sure I can use that SDK anymore.
So does anybody know is this possible with Photoshop scripting or should I better use some other tool? In that case what tool?
Actions and scripting
4.2K
Explorer , Dec 08, 2016 Dec 08, 2016
Alternatively you can use the same bridge script you referenced but modified a bit:
#target bridge
var bitmap = new BitmapData(16, 16);
var output = new File(Folder.desktop + "/Bitmap Test File.jpg");
var colours = [];
function createColours(){
    for(var i = 0; i < 256; i++){
        var hex = i.toString(16);
        var colourVal = hex.length == 1 ? "0" + hex : hex;
        colours.push(String('#' + colourVal + colourVal + colourVal));
    shuffle(colours);
function shuffle(array){
    var i = a
Adobe
Assuming that you're only using a 16x16 px canvas
var doc = app.activeDocument;
var fillColor = new SolidColor();
var step = 0;
for(var y = 0; y < 16; y++){
    for(var x = 0; x < 16; x++){
        doc.selection.select([[x, y], [x, y + 1], [x + 1, y + 1], [x + 1, y]], SelectionType.REPLACE);
        fillColor.rgb.hexValue = String(toHex(step) + toHex(step) + toHex(step));
        doc.selection.fill(fillColor);
        step++;
doc.selection.deselect();
function toHex(c) {
    var hex = c.toString(16);
    return hex.length == 1 ? "0" + hex : hex;
Of course the 16x16 canvas has 256 total pixels and there are only 256 greyscale values to fill it so it becomes a gradient
#target bridge
var colours = [];
    shuffle(colours);
    var i = array.length;
    var j = 0;
    var tempVal;
    while (i--) {
        j = Math.floor(Math.random() * (i + 1));
        tempVal = array;
        array = array;
        array = tempVal;
    createImage(array);
function createImage(shuffledColours){
    var step = 0;
    for(var y = 0; y < bitmap.height; y++){
        for(var x = 0; x < bitmap.width; x++){
            bitmap.setPixel(x, y, shuffledColours[step]);
            step++;
    bitmap.exportTo(output, 100);
createColours();
This results in an image like this:
Of course this is scaled up beyond 16px
Dec 09, 2016 Dec 09, 2016
Thanks for the good answer!
I liked the 2nd implementation better as it's faster. Your code outputs to jpg. The documentation seemed to indicate that BitmapData could output to PNG's as well but I didn't manage to get that working.
I did see some compression artifacts even with 100% quality, see colour levels. Not a big deal but preferably I would like to get a perfect result
The exportTo() only saves in JPG format according to documentation. You can change the file name on line 4 from ".jpg" to ".png" and that seems to change the filetype but it's probably still under JPG compression. I'm curious as to what you're going to use this for
Also, would you mark my code reply as answering your question?
It's for a game. So the texture will be converted to dds and used in a shader.
I normally work with graphics code in C++ but for this I wanted to try out if javascript+photoshop was a good alternative.
I'm totally appreciating your advice and the result is almost perfect. However in the long run I might look out for other tools/environments to do these kind of tasks in the future.
Participant ,
Dec 10, 2016 Dec 10, 2016
You can also write the data with binary encoding to a raw file using File.write(), and then open the raw image and save it in whatever format you wish.
Enthusiast ,
Dec 11, 2016 Dec 11, 2016
If you normaly work with C++ you could be interested in Photoshop SDK
In examples is "disolve filter" and you can modify code and set to layer any pixels you want.
It should be faster than anything else and you can apply this filter to smart object and so on.
This example supports 8bit, 16bit and 32bit per channel and also CMYK.
13923292_1302261026470379_7817625681848121845_o.jpg?oh=4e0897a7e2e8d8c1452da9b2a56e552f&oe=58E8D10A
And there are also examples for file-formats. So you can open/save your custom file-format.
