export project from AE into PP - lost features
Participant ,
Dec 08, 2016 Dec 08, 2016
I made a project in AE (from scratch) where I combine to different video clips. They are in three compositions (3 chapters deep) including some opacity masks,  tracking data, and null object with one sub-composition parented to. I'm satisfied with result and want to use as a sequence in exisiting unfinishied Premiere project. However after exporting, it doesnt look the same - I've lost masks, tracking data, and some transform data as well.
Is there any sollution?
Michal
815
Participant , Dec 19, 2016 Dec 19, 2016
I've managed creating new dynamic linked composition and then pasting all of the assets and data:)
how are you exporting? show us what happened so we can be specific in our workflow suggestions.
provide additional information such as Ae version full numbers, Os version because these could be important.
Participant ,
Dec 09, 2016 Dec 09, 2016
AE version 14.0.1.5
Windows 10 Pro
There are few screenshots, I hope you can see the details;
This is the upper composition, just Warp stabilizer applied:
Level down - based on the bottom footage tracking data are applied to null object above. The top comp includes roto/opacity masks and transform adjustments. This one is linked to null object for tracking.
The last (top) comp - still image and video. Stablilizer applied to video.
I export using command File- export- adobe premiere pro project. The main composition looks like this.
The problem occures in it's sub-sequence:
No masks and their keyframes. Transform data correct.
Null object properties. There are keyframes.
Participant ,
Dec 13, 2016 Dec 13, 2016
Does anyone else can help with my problem please?
you seem to not know the limitation of working across these two apps - this is not how it works. you have a few ways to work between these two applications and keeping things "Live" but this is not it. I suggest you watch this tutorial:Adobe Premiere Pro to After Effects Workflow - Tutorial - YouTube about working between both apps. in the meantime, I'd suggest you render your composition in Ae and use it in Premiere as a rendered movie.
Participant ,
Dynamic link is a way of having a self contained Ae composition in Premiere and a live connection between the two apps. Edit in Ae, you even don't have to save it - and it's in Premiere. Pro's: you don't render, you can fix things as you work without rerendering. Con's: since it has to process the layers in Ae, playback in premiere is slow, sometimes to the point of inefficient. Also other errors can creep in especially when using effects like 3D Camera tracker or Rotobrush. Advice: if you are basically done with the compositing, Render your footage to a production codec and use it as a regular clip in Premiere.
Participant ,
Dec 21, 2016 Dec 21, 2016
is there any loss of quality when rendering to this codec?
when rendering to a lossless production codec there is no loss of quality. you should chose the proper codec based on your compositing settings. if 8 bit is o.k, you can use QT Animation.
Participant ,
I'll keep it in mind. Thanks for help
