While doing multiple copy option in a file, the ADE (all versions) are stopped working suddenly. Can you please suggest a solution to resolve the problem.
Do used which operation system? Have you all Version installed of Digital Edition to the same time?
No we have not installed all versions at the same time.We found the issue with windows XP, windows 2008 R2 OS.
Windows XP should used only Digital Edtion 3.0. No version of 4.0 and more this version to new for XP. You used the software with admin rights?
We installed the application by admin rights.But the application is used by normal user only. Also suggest why the ADE is also stopped in windows 2008 R2 server. The PC is installed with windows updates and java is also in current version. FYI
i have no server. So can not say if it work or not. I only know that windows xp user for digital eiditon should used admin rights of the folder of the programm so that can work fine.
