I am making PDFs 508 compliant (complying with ADA requirements). Using the accessibility checker, I perform a full accessibility check. After I perform the accessibility check, random characters appear in the PDF -- usually exclamation points. I can remove the exclamation points, however, the formatting is affected. Has anyone seen this and is there a solution?
[Moved from non-technical Forum Lounge to specific Program forum... Mod]
[Here is the list of all Adobe forums... https://forums.adobe.com/welcome]
Hi amieef92602956,
I am sorry for the delayed response.
Could you please confirm the version of Acrobat installed on the machine?
Try to run accessibility check on another pdf and check if the file produces the same result.
Thank You,
Shivam
