Hello, all,
I was just shown that an application written by someone else over ten years ago is working fine under CF9 and CF10; but it's breaking in CF11.
I have something like:
<cfinclude template="../myComponent.cfc" />
Now, in myComponent.cfc, I have a function:
<cffunction name="getThisAttribute" returntype="string" output="no">
<cfargument name="part1" /><cfargument name="part2" />
<cfreturn thisValue />
</cffunction>
Under CF11, in the first page (again, this works in CF9 and CF10), if I do the following:
<cfset thisVar = getThisAttribute(part1,'part2') />
I get "getThisAttribute undefined". Am I going to have to completely re-write how all this works if we switch to CF11???
V/r,
^_^
Not quite kosher code, but it should work. What about:
<cfset thisVar = getThisAttribute('part1','part2') />
or
<cfset thisVar = getThisAttribute(1,2) />
Thanks for the suggestion, BKBK​, but getThisAttribute is a function in the CFC that is CFINCLUDEed prior to the CFSET; but CF is convinced that getThisAttribute is not defined. It's not the arguments that are preventing anything - it just doesn't exist.
I thought perhaps that it might be because the CFC is CFINCLUDE, not a component that is mapped and accessed via <cfset thisVar = new components.getThisAttribute(part1,'part2') />, but that is weird since it works in CF9/10.
V/r,
^_^
To me this looks like a bug in CF9 & 10 that you unintentionally exploited. The getThisAttribute appears to be defined as a function of the myComponent and nowhere are you reverencing a myComponent instance. Now if your first module was a cfc and you used the extends="myComponent" parameter, then your cfset call should work -- although on occasion I have had to explicitly state this.getThisAttributes(...) for unknown reasons.
I'll give the extends="myComponent" a shot. Thanks!
V/r,
^_^
WolfShade wrote:
... but CF is convinced that getThisAttribute is not defined. It's not the arguments that are preventing anything - it just doesn't exist.
Coldfusion may see a function with wrong or different arguments as different from the function in the component. If after making the changes I suggested you still get the error then verify whether the path .../myComponent.cfc is correct.
In any case, as everyone has said, you should just correct the code. Either remove the cfcomponent tag and revert to CFMs, or define the CFC in a separate file and access the function via createobject("component","path-to-component").functionName().
Remember, there is one good reason to do the right thing. If you don't, those who inherit the code from you will blame it on you.
Just curious - I prefer <cfset varName = new component.path.to.cfc.functionName(args) /> when the this.mappings is used. Is there a benefit to using createObject(), instead?
V/r,
^_^
Creating a component by means of createobject or new amounts to the same thing. However, I would separate the creation of the object from the function call. That frees the object up for reuse.
That's definitely not how CFC's are supposed to be used.
I suspect the quickest solution would be to rename the CFC file to a CFM file and do a search and replace in all scripts that include the file.
Cheers
Eddie
Oh, I know. I inherited this code, it was written over ten years ago (round about CF MX6 or MX7, methinks), and I'm personally hoping that it is so old, outdated, and just plain vulnerable that the client will agree to just deleting the whole thing, possibly writing another from scratch.
V/r,
^_^
