Hello I have been using After effects 2015.3. When I was rigging my character the warning come up I tried to click ok untill it gone. After that I moved the puppet tool the program crashes and shut my computer down. It happened when I'm moving the puppet tool. I through it because of my computer RAM but I already add more RAM yesterday now I have 16 GB. My laptop window is window 10. I would like to know how can I fixed this problem?
make sure its 13.8.1
this could be many things. let's try the obvious:
Hello, My GPU is GeForsce GTX 960M
My AE is 13.8.1
I will try to reset the preference. I have the same problem with you MisiSipos80​. My other computer also can work quite well.
Hope can solve this problem soon
Thank you
It seems it is somehow connected with the custom layout? I reset the workspace and it works. Weird!
Same thing here. When using my customized workspace, the error occurs. Switching to the standard one and everything works. I agree, it's extremely annoying. It started after I purged all memory & disk cache.
[EDIT] I created a new workspace, deleted it, tried to select another one and AE gave a pop-up error, telling me workspace.xml wasn't valid, that he would use a backuped file instead. All I could do is click "Proceed" and so far, the previews are working.
Any luck?
Adobe After Effects 2017 randomly started having this error for me as well.
I RESET MY WORKSPACE TO SAVED and it stopped immediately.
Not fun, but it worked. FOR NOW.
Same here. I switched to the standard layout and had no problems.
Anyone at Adobe on this thread? Could you helps shed some light on this?
Using the latest version of AE and getting the same issue. The workaround of resetting the workspace works for me too, but it's annoying to have to do so.
Adobe, are you looking into this?
The reset Workspace workaround worked for me so thanks for that, but now RAM Preview seems a lot slower.
Not sure if that is because it is actually RAM previewing now.
Please sort this out Adobe, yes?
I can confirm the previous poster's solution:
Simply revert to one of your default workspaces (e.g. Effects) and then reorganize your personal panels in a new workspace. (Don't save over your old one, make a new name for it).
This solves the problem. Perhaps Adobe will solve this inconvenience in a future patch.
@Adobe Have you actually fixed that after 7 months? Re-organizing work space is a pretty basic thing, or at least it should be.
Any update on that?
The 14.2 update that came out a couple of weeks ago did fix some crashing issues with workspaces. Is it not working for you?
No it did not.
In fact I was working on a job for 2 weeks now and I reorganized my workplace. It has been working without any problems. So yesterday I switched off my computer, today I switch it on and vioala "unspecified drawing error" is back. No, there was no Win updates downloaded in fact any updates, unless my computer woke up secretly tonight and decided to do so.
So again, thank you Adobe for,
1. Not replying
2. Not fixing that ridiculous issue
I think they have no idea what is that error. It is like "signal error" on London undergrounds.
1. Not replying
This is a user-to-user forum. It's a place for people like us to try to help each other with problems. If you want a response from an Adobe employee, you'll need to contact Adobe support.
If you want them to fix issues, it would also be quite beneficial to file bug reports with as much detail as possible so that they can try to recreate the bug issue on their end (and let them know if you can provide crash logs, corrupted workspace files, etc.). It's the best way to get your issue in front of the eyes of the actual After Effects team. Granted, they usually don't respond to individual bug reports, but they do read them and fix the bugs.
I'm on a new machine at work, getting same issue during RAM preview (WI 10 machine, with latest AE update). This is super annoying, and resetting to the "standard" workspace is not an acceptable solution. I hope Adobe is monitoring this issue.
That would be really annoying!
You can be sure that they are by filing a bug report at this link. It goes right to the Adobe After Effects team. Like, it goes to a human who actually works on After Effects who reads it, logs it, and puts it into the list (the more reports/severity, the higher up the priority list it goes, by the way, so anyone who can't fix this issue should file a report too). The bug report/feature request form is the best way to get issues to their attention. Provide as much detail as you can so they can hopefully recreate the issue on their end in one of their test machines. You can't fix what you can't see! (Well, sometimes you can, but it's really hard.)
okay, done. Where's my treat
Hopefully it comes in the form of AE working properly in a future update! However, since I'm just a user like you, you have my thanks, but I can't give you much else. If you're anywhere near Nashville, TN, I could buy you a beer or something.
Hi Guys, I've reset my workspace; standard to default ... and now I don't have these warnings...
That pretty much renders the arranging workspace feature pointless and useless.
comigo, eu precisei reconfigurar a saÃda de áudio no painel de configurações. sempre acontece este erro quando eu mudo para um dispositivo e assim que este dispositivo de áudio não está mais no computador o after não entende e altera automaticamente para algum disponÃvel, daà ele responde com este problema.
Valeu mesmo, vc me salvou!!!@upslon
And yet another bug, killing my workflow. Ive spent more time troubleshooting AE during the last few weeks than I have spent on making stuff! I have resisted it for so long, but Fusion, Inkscape, Gimp etc here I come. F*** you Adobe.
I have a new one lately, something about loading OpenGL command.
I already moved to Fusion, Davinci and when it comes to mograph, there isn't anything that I cant do in C4D. I very much understand your final statement. It is ridiculous that after every update I have new errors with AE and zero solution for years.
