Iteration Counter
Contributor ,
Dec 09, 2016 Dec 09, 2016
Hi, i am trying to create an expression, that counts the number of iterations, a formula needs to reach a given value, and am wondering if this is even possible in AE, since i could not find anything like this online... I tried the following:
var t=1;
var i=0;
if (t<5) {t+1, i+1};
I would like i to return 4 in this case, but it always returns 0. Any Suggestions?
Thanks a lot,
Expressions
689
Community Expert , Dec 09, 2016 Dec 09, 2016
Expressions have no memory, so incrementing a variable for the next frame won't work. Depending on what you're trying to do, you can usually do the necessary calculations using time, the current comp time.
Dan
Dan
Contributor ,
Thanks, dan, that was what i feared. Maybe i will get it to work using time... do you know by any chance, whats the smallest increment of time i can use? is it a Frame? or is it smaller? Thanks for your help...
time represents seconds since the start of the comp. You can use any fractional value you want. The duration of a single frame is available with thisComp.frameDuration.
Dan
Contributor ,
Thanks again! I think i was sloppy, describing my initial problem, i just got it to work using the following code:
i=0;
t=1;
while(t < 5){
i++, t=t+2;
Have a nice evening:)
