So I updated my Lr to 6.8 last night (I do not have CC, I dislike subscription based software) and now it won't open saying that is missing a DLL file. The DLL missing is related to C++ Runtime.
Anyone else have this issue?
*working on finding the DLL name
Windows 7
Here's how I fixed it for me; Adobe support did not help.
api-ms-win-crt-runtime-l1-1-0.dll is missing when opening Microsoft Office file - Stack Overflow
Hi HeldInTheMoment,
Could you please post the exact error message with a screenshot here?
Akash
Sorry, I am not at home to get a screen shot; though, the missing DLL file is [api-ms-win-crt-runtime-l1-1-0.dll]
I have downloaded the DLL and placed in the System32 Folder, then I get the following error: "The procedure entry point ucrtbase.terminate could not be located in the dynamic link library api-ms-win-crt-runtime-l1-1-0.dll."
Thank you; though, the installer just sits at "Searching for updates on this computer"...
to make it worse, I cannot get 6.7 back...it's either 6.0 or bust
Same here.
What's your OS?
Windows 7
HeldInTheMoment
You are the man!
I used your link and followed the instructions.
No idea what I was doing, but it worked nevertheless.
Thank you so much!
Ulrich..........what directions did you follow to fix your problem?
thanks!!!
Pete,
if you scroll up this thread by 6 posts to HeldInTheMoment's from 09.12.2016 15:46 you will find a link. Okay?
Hit it and another page will open. Some Computer programmer's help page, I guess.
Topic there is like 'MS office problem blabla'. But anyway.
Scroll down to the very bottom and find this message:
Actually, I didn't do the 'Kill all temp files' thing. Frankly, because I hadn't any idea, how to do the search.
What I did do is the 'clean boot'. A never seen before feature to me...
And finally I downloaded and started vc_redist.x64.
It took some time to finish, be patient (several minutes!).
To be on the safe side I rebootet once again, this time w/o 'clean boot'.
So make sure to reset the according msconfig option.
That's all. And LR 6.8 is functioning since.
Again I am running Windows7 x64.
As all links go back to Microsoft servers it should be safe from my point of view.
You may realize I am no computer nerd at all,still I could do it.
And so can you!
All credits to HeldInTheMoment and Shashank Singh.
Ulrich.....thanks for the help!!
I still can't solve the problem on my computer. Running Win 7 (64). Tried all of the above actions. But no luck. I don't want to go back to LR 6.0. Maybe Adobe has some answers !!!!thanks again !!Copy link to clipboard
Have exactly the same error. had to reinstall 6.0. running win7.
Yes.....when trying to run this.....I just get the window "searching for updates" which goes on forever!!!
Open Event Viewer and look for recent errors and then copy the crash log.
See link for Elements & Lightroom
https://helpx.adobe.com/photoshop-elements-editor/using/find-crashlogs.html
12/08/16 18:49:12:439 | [INFO] | | HDSetup | HDSetup | AppContext | | HDSetup | 3069164 | ************************* START Adobe Setup *************************
12/08/16 18:49:12:439 | [INFO] | | HDSetup | HDSetup | AppContext | | HDSetup | 3069164 | Adobe Setup Version: 3.9.1.335
12/08/16 18:54:26:606 | [INFO] | | HDSetup | HDPIM | HDPIMSessionManager | | HDPIM | 3069196 | Inside hdpimCreateSession
12/08/16 18:54:26:648 | [INFO] | | HDSetup | HDPIM | HDPIMSessionManager | | HDPIM | 3069196 | Entering into 'createHDPIMSession'
12/08/16 18:54:26:690 | [ERROR] | | HDSetup | HDPIM | ProgressManager | | HDPIM | 3069196 | Error in stoping manager threads
12/08/16 18:54:26:690 | [INFO] | | HDSetup | HDPIM | HDPIMSessionManager | | HDPIM | 3069196 | new session '1C2E9C50-257C-4EC6-A907-79DD33A29EF7' created
12/08/16 18:54:26:691 | [INFO] | | HDSetup | HDPIM | HDPIMSessionManager | | HDPIM | 3069196 | Exiting hdpimCreateSession, new session ID is '1C2E9C50-257C-4EC6-A907-79DD33A29EF7'
12/08/16 18:54:26:754 | [INFO] | | HDSetup | HDPIM | HDPIMSessionManager | | HDPIM | 3069196 | Inside hdpimInstallProduct with request <?xml version="1.0" encoding="UTF-8"?>
<DriverInfo>
<ProductInfo>
<SAPCode>ACR</SAPCode>
<CodexVersion>9.8</CodexVersion>
<Platform>osx10-64</Platform>
<BuildVersion>9.8.0.63</BuildVersion>
</ProductInfo>
<RequestInfo>
<ClientWorkingDirectory>/tmp/E30FB9C5-624F-4CAB-BB50-62DDCEEF857D</ClientWorkingDirectory>
<InstallDir></InstallDir>
<PackageServiceURL>https://prod-rel-ffc-ccm.oobesaas.adobe.com/adobe-ffc-external/core/v2/applications</PackageServiceURL>
<x-api-key>CreativeCloud_v3_9</x-api-key>
<prefMigration>FALSE</prefMigration>
<PreserveInstallData>true</PreserveInstallData>
<ConflictXML>/tmp/E30FB9C5-624F-4CAB-BB50-62DDCEEF857D/746F30B3-3E20-42A5-82D5-3BFE5D7520BD</ConflictXML>
<DeleteUserPreferences>false</DeleteUserPreferences>
</RequestInfo>
</DriverInfo>
12/08/16 18:54:26:756 | [INFO] | | HDSetup | HDPIM | HDPIMSessionManager | | HDPIM | 3069196 | Exiting hdpimInstallProduct with status '0'
12/08/16 18:54:28:438 | [INFO] | | HDSetup | OOBEUtils | FileUtils | | OOBEUtils | 3094218 | Successfully deleted directory from path: /tmp/C9FE5B35-E6C1-480E-B9B1-753B7BF9CE94. Recursive: 1
12/08/16 18:54:28:439 | [INFO] | | HDSetup | HDPIM | ApplicationManager | | HDPIM | 3094218 | Populating install data from Application JSON
12/08/16 18:54:28:484 | [INFO] | | HDSetup | HDPIM | ApplicationManager | | HDPIM | 3094218 | Previous codex version '9.7' found installed on machine. Updating to requested codex version '9.8'
12/08/16 18:54:28:516 | [INFO] | | HDSetup | HDPIM | ApplicationManager | | HDPIM | 3094218 | Sanitizing data for product-'Camera Raw CC'
12/08/16 18:54:28:516 | [INFO] | | HDSetup | HDPIM | ApplicationManager | | HDPIM | 3094218 | HD Packager Version-'0.0.136'
12/08/16 18:54:28:531 | [INFO] | | HDSetup | HDPIM | ApplicationManager | | HDPIM | 3094218 | Sorting packages to install
12/08/16 18:54:28:531 | [INFO] | | HDSetup | HDPIM | ApplicationManager | | HDPIM | 3094218 | Package (Name: CameraRawRIBSCoExistPackage Version: 9.6.0.126) selected for install (replacing package (Name: CameraRawRIBSCoExistPackage Version: 9.6.0.126))
12/08/16 18:54:28:531 | [INFO] | | HDSetup | HDPIM | ApplicationManager | | HDPIM | 3094218 | Package (Name: AdobeCameraRaw8.0All Version: 9.8.0.63) selected for install (replacing package (Name: AdobeCameraRaw8.0All Version: 9.7.0.112))
12/08/16 18:54:28:531 | [INFO] | | HDSetup | HDPIM | ApplicationManager | | HDPIM | 3094218 | Package (Name: AdobeCameraRawProfile8.0All Version: 9.8.0.63) selected for install (replacing package (Name: AdobeCameraRawProfile8.0All Version: 9.7.0.112))
12/08/16 18:54:28:532 | [INFO] | | HDSetup | HDPIM | TaskManager | | HDPIM | 3094365 | Starting 'DOWNLOAD' task for Package (Name: AdobeCameraRaw8.0All Version: 9.8.0.63)
12/08/16 18:54:28:532 | [INFO] | | HDSetup | HDPIM | TaskManager | | HDPIM | 3094367 | Starting 'UN-INSTALL' task for Package (Name: CameraRawRIBSCoExistPackage Version: 9.6.0.126)
12/08/16 18:54:28:532 | [INFO] | | HDSetup | HDPIM | DownloadManager | | HDPIM | 3094365 | Package (Name: AdobeCameraRaw8.0All Version: 9.8.0.63) Download info - DownloadSize: 46875099, DownloadPath:'/tmp/8FDCD8B4-5B0B-4FD5-9D6A-F1E2263106BF'
12/08/16 18:54:28:535 | [INFO] | | HDSetup | HDPIM | TaskManager | | HDPIM | 3094367 | Completed 'UN-INSTALL' task for Package (Name: CameraRawRIBSCoExistPackage Version: 9.6.0.126), Time taken '0' sec
12/08/16 18:54:28:535 | [INFO] | | HDSetup | HDPIM | TaskManager | | HDPIM | 3094367 | Starting 'INSTALL' task for Package (Name: CameraRawRIBSCoExistPackage Version: 9.6.0.126)
12/08/16 18:54:28:540 | [INFO] | | HDSetup | HDPIM | TaskManager | | HDPIM | 3094367 | Completed 'INSTALL' task for Package (Name: CameraRawRIBSCoExistPackage Version: 9.6.0.126), Time taken '0' sec
12/08/16 18:54:48:139 | [INFO] | | HDSetup | HDPIM | TaskManager | | HDPIM | 3094366 | Starting 'EXTRACT' task for Package (Name: AdobeCameraRaw8.0All Version: 9.8.0.63)
12/08/16 18:54:48:139 | [INFO] | | HDSetup | HDPIM | TaskManager | | HDPIM | 3094365 | Completed 'DOWNLOAD' task for Package (Name: AdobeCameraRaw8.0All Version: 9.8.0.63), Time taken '20' sec
12/08/16 18:54:48:139 | [INFO] | | HDSetup | HDPIM | TaskManager | | HDPIM | 3094365 | Starting 'DOWNLOAD' task for Package (Name: AdobeCameraRawProfile8.0All Version: 9.8.0.63)
12/08/16 18:54:48:139 | [INFO] | | HDSetup | HDPIM | ExtractManager | | HDPIM | 3094366 | Package (Name: AdobeCameraRaw8.0All Version: 9.8.0.63) Extract info - ExtractSize: 68612155, ExtractPath:'/.adobeTemp/CDAE7A76-696E-47AF-80E0-F15C40CD1D3E'
12/08/16 18:54:48:140 | [INFO] | | HDSetup | HDPIM | DownloadManager | | HDPIM | 3094365 | Package (Name: AdobeCameraRawProfile8.0All Version: 9.8.0.63) Download info - DownloadSize: 240606241, DownloadPath:'/tmp/116A4C46-B929-4476-BF1A-6D31028C6F35'
12/08/16 18:54:48:217 | [INFO] | | HDSetup | HDPIM | HDZIPHelper | | HDPIM | 3094366 | starting decompression of file /tmp/8FDCD8B4-5B0B-4FD5-9D6A-F1E2263106BF/AdobeCameraRaw8.0All.zip to folder /.adobeTemp/CDAE7A76-696E-47AF-80E0-F15C40CD1D3E with type Zip-Deflated
12/08/16 18:54:49:117 | [INFO] | | HDSetup | HDPIM | HDZIPHelper | | HDPIM | 3094366 | completed decompression of file /tmp/8FDCD8B4-5B0B-4FD5-9D6A-F1E2263106BF/AdobeCameraRaw8.0All.zip at folder /.adobeTemp/CDAE7A76-696E-47AF-80E0-F15C40CD1D3E with type Zip-Deflated with status code 0
12/08/16 18:54:49:120 | [INFO] | | HDSetup | OOBEUtils | FileUtils | | OOBEUtils | 3094366 | Successfully deleted directory from path: /tmp/8FDCD8B4-5B0B-4FD5-9D6A-F1E2263106BF. Recursive: 1
12/08/16 18:54:49:120 | [INFO] | | HDSetup | HDPIM | TaskManager | | HDPIM | 3094367 | Starting 'UN-INSTALL' task for Package (Name: AdobeCameraRaw8.0All Version: 9.7.0.112)
12/08/16 18:54:49:120 | [INFO] | | HDSetup | HDPIM | TaskManager | | HDPIM | 3094366 | Completed 'EXTRACT' task for Package (Name: AdobeCameraRaw8.0All Version: 9.8.0.63), Time taken '1' sec
12/08/16 18:54:57:382 | [INFO] | | HDSetup | HDPIM | TaskManager | | HDPIM | 3094367 | Completed 'UN-INSTALL' task for Package (Name: AdobeCameraRaw8.0All Version: 9.7.0.112), Time taken '8' sec
12/08/16 18:54:57:382 | [INFO] | | HDSetup | HDPIM | TaskManager | | HDPIM | 3094367 | Starting 'INSTALL' task for Package (Name: AdobeCameraRaw8.0All Version: 9.8.0.63)
12/08/16 18:54:57:910 | [INFO] | | HDSetup | OOBEUtils | FileUtils | | OOBEUtils | 3094367 | Successfully deleted directory from path: /.adobeTemp/CDAE7A76-696E-47AF-80E0-F15C40CD1D3E. Recursive: 1
12/08/16 18:54:57:910 | [INFO] | | HDSetup | HDPIM | TaskManager | | HDPIM | 3094367 | Completed 'INSTALL' task for Package (Name: AdobeCameraRaw8.0All Version: 9.8.0.63), Time taken '0' sec
12/08/16 18:56:22:905 | [INFO] | | HDSetup | HDPIM | TaskManager | | HDPIM | 3094366 | Starting 'EXTRACT' task for Package (Name: AdobeCameraRawProfile8.0All Version: 9.8.0.63)
12/08/16 18:56:22:905 | [INFO] | | HDSetup | HDPIM | TaskManager | | HDPIM | 3094365 | Completed 'DOWNLOAD' task for Package (Name: AdobeCameraRawProfile8.0All Version: 9.8.0.63), Time taken '94' sec
12/08/16 18:56:22:905 | [INFO] | | HDSetup | HDPIM | ExtractManager | | HDPIM | 3094366 | Package (Name: AdobeCameraRawProfile8.0All Version: 9.8.0.63) Extract info - ExtractSize: 635769707, ExtractPath:'/.adobeTemp/E064C267-15C4-469C-BB55-B7F68565DB2B'
12/08/16 18:56:22:905 | [INFO] | | HDSetup | HDPIM | HDZIPHelper | | HDPIM | 3094366 | starting decompression of file /tmp/116A4C46-B929-4476-BF1A-6D31028C6F35/AdobeCameraRawProfile8.0All.zip to folder /.adobeTemp/E064C267-15C4-469C-BB55-B7F68565DB2B with type Zip-Deflated
12/08/16 18:56:38:823 | [INFO] | | HDSetup | HDPIM | HDZIPHelper | | HDPIM | 3094366 | completed decompression of file /tmp/116A4C46-B929-4476-BF1A-6D31028C6F35/AdobeCameraRawProfile8.0All.zip at folder /.adobeTemp/E064C267-15C4-469C-BB55-B7F68565DB2B with type Zip-Deflated with status code 0
12/08/16 18:56:38:836 | [INFO] | | HDSetup | OOBEUtils | FileUtils | | OOBEUtils | 3094366 | Successfully deleted directory from path: /tmp/116A4C46-B929-4476-BF1A-6D31028C6F35. Recursive: 1
12/08/16 18:56:38:836 | [INFO] | | HDSetup | HDPIM | TaskManager | | HDPIM | 3094366 | Completed 'EXTRACT' task for Package (Name: AdobeCameraRawProfile8.0All Version: 9.8.0.63), Time taken '16' sec
12/08/16 18:56:38:836 | [INFO] | | HDSetup | HDPIM | TaskManager | | HDPIM | 3094367 | Starting 'UN-INSTALL' task for Package (Name: AdobeCameraRawProfile8.0All Version: 9.7.0.112)
12/08/16 18:56:44:647 | [INFO] | | HDSetup | HDPIM | TaskManager | | HDPIM | 3094367 | Completed 'UN-INSTALL' task for Package (Name: AdobeCameraRawProfile8.0All Version: 9.7.0.112), Time taken '6' sec
12/08/16 18:56:44:647 | [INFO] | | HDSetup | HDPIM | TaskManager | | HDPIM | 3094367 | Starting 'INSTALL' task for Package (Name: AdobeCameraRawProfile8.0All Version: 9.8.0.63)
12/08/16 18:56:45:398 | [INFO] | | HDSetup | OOBEUtils | FileUtils | | OOBEUtils | 3094367 | Successfully deleted directory from path: /.adobeTemp/E064C267-15C4-469C-BB55-B7F68565DB2B. Recursive: 1
12/08/16 18:56:45:398 | [INFO] | | HDSetup | HDPIM | TaskManager | | HDPIM | 3094367 | Completed 'INSTALL' task for Package (Name: AdobeCameraRawProfile8.0All Version: 9.8.0.63), Time taken '1' sec
12/08/16 18:56:46:893 | [WARN] | | HDSetup | OOBEUtils | XMLParser | | OOBEUtils | 3094218 | ERROR invalid xml file path. Could not read data from path /Library/Application Support/Adobe/PCF/{ACR-9.7-64-ADBEADBEADBEADBEADBEADBEA}..xml
12/08/16 18:56:46:956 | [WARN] | | HDSetup | OOBEUtils | XMLParser | | OOBEUtils | 3094218 | Error Description Error Domain=NSCocoaErrorDomain Code=260 "The file “{ACR-9.7-64-ADBEADBEADBEADBEADBEADBEA}..xml” couldn’t be opened because there is no such file." UserInfo={NSFilePath=/Library/Application Support/Adobe/PCF/{ACR-9.7-64-ADBEADBEADBEADBEADBEADBEA}..xml, NSUnderlyingError=0x78e121c0 {Error Domain=NSPOSIXErrorDomain Code=2 "No such file or directory"}}
12/08/16 18:56:47:327 | [INFO] | | HDSetup | OOBEUtils | FileUtils | | OOBEUtils | 3094218 | Successfully deleted directory from path: /Library/Application Support/Adobe/Uninstall/ACR_9_7.app. Recursive: 1
12/08/16 18:56:47:900 | [INFO] | | HDSetup | HDSetup | AppContext | | HDSetup | 3094217 | Exit Code: 0
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 1 error(s), 2 warnings(s)
ERROR: Error in stoping manager threads
WARN: ERROR invalid xml file path. Could not read data from path /Library/Application Support/Adobe/PCF/{ACR-9.7-64-ADBEADBEADBEADBEADBEADBEA}..xml
WARN: Error Description Error Domain=NSCocoaErrorDomain Code=260 "The file “{ACR-9.7-64-ADBEADBEADBEADBEADBEADBEA}..xml” couldn’t be opened because there is no such file." UserInfo={NSFilePath=/Library/Application Support/Adobe/PCF/{ACR-9.7-64-ADBEADBEADBEADBEADBEADBEA}..xml, NSUnderlyingError=0x78e121c0 {Error Domain=NSPOSIXErrorDomain Code=2 "No such file or directory"}}
12/08/16 18:56:48:000 | [INFO] | | HDSetup | HDPIM | HDPIMSessionManager | | HDPIM | 3069196 | Inside hdpimTerminateSession
12/08/16 18:56:48:021 | [INFO] | | HDSetup | HDPIM | HDPIMSessionManager | | HDPIM | 3069196 | Exiting hdpimTerminateSession, successfully closed session '0'
12/08/16 18:56:48:026 | [INFO] | | HDSetup | HDSetup | AppContext | | HDSetup | 3069164 | Exit Code: 0
12/08/16 18:56:48:063 | [INFO] | | HDSetup | HDSetup | AppContext | | HDSetup | 3069164 | ************************* END Adobe Setup *************************
Clearly not the same issue
