Archived Project, Text has moved
Participant ,
Dec 10, 2016 Dec 10, 2016
I have an archived project that I had copied and now want to burn another disk from it. However when I go and preview it my text has "moved" and so have some of my jpeg files have resized. When I say "moved" I mean that they have moved in the positioning on the jpeg image. Also now when I go into the project to edit it, it will not "save" it the way that I re- edit. I am using Windows 10 PE 12.
Any insight would be great Thanks
236
Participant , Dec 10, 2016 Dec 10, 2016
Steve,
Okay this was one of my earlier projects, and after looking at the files closer, I believe what was happening is that I was previewing it by manually moving the time line indicator. When I stopped doing that and went back to the beginning of the project and let it automatically play to check the clips it no longer presented with the same problem. The jpegs were sized correctly along with the text.
I have since learned that I need to archive my files and burn more than one disk at the time
Are you editing this project on the same computer as you began it on?
Based on the information you've provided, it's not at all clear what different factors are affecting your video project.
Participant ,
Steve,
I have since learned that I need to archive my files and burn more than one disk at the time I am working and finalizing the project. I like to have a back up disk in the event my "one and only" gets destroyed.
Thanks for responding. It is always appreciated.
If it's the menu you are referring to, it could be a problem with that particular menu.  What template are you using?
Dec 11, 2016 Dec 11, 2016
Glad to hear you've figured it out, AZ. Please mark this question as correctly answered.
