The "X" keyboard shortcut to mark a photo as rejected does not work anymore in today's LR update, in the Grid module.
Instead it toggles the information displayed in each photo cell.
The shortcut still works in the bottom ribbon when working in the Develop module, though.
And the "P" and "U" shortcuts to mark a photo as a pick or unmark it still work in the Grid and Develop modules.
Do Help > System Info to verify you are actually running CC 2015.8 / 6.8 -- LR often fools people into thinking they got the latest update.
If you are running 2015.8, then it may be that Adobe screwed up the fix to a bug with the "x" shortcut. Please add details about your issue to this bug report in the official Adobe feedback forum: Lightroom: x keyboard shortcut is assigned to two functions in Library module [Swedish language] | Photoshop Family Cust…
Works here in grid mode. OS X 10.11.6 Lr 2015.8.
What is the language setting in Lr and keyboard?
If you are running 2015.8, then it may be that Adobe screwed up the fix to a bug with the "x" shortcut. Please add details about your issue to this bug report in the official Adobe feedback forum: Lightroom: x keyboard shortcut is assigned to two functions in Library module [Swedish language] | P...
Works here with German language set.
I have the X shortcut issue, running Lightroom 6.8 in French under OS X.
CAPS+X works, but not X alone...
Did you try to reset the preferences: Resetting Preferences in Lightroom CC/6
This has been acknowledged as an issue. Please see here for more info: Lightroom CC 2015.8: Shortcut X to reject an image in Library not available (French & Dutch) | Photo...
Melissa
Hi marcl,
Please update Lightroom to 6.9/2015.9 version which includes the fix for Lightroom CC 2015.8: Shortcut X to reject an image in Library not available (French) | Photoshop Fam...
refer: Lightroom CC 2015.9 now available
Mohit
