Hi all,
I suspect that during import, my 'Date Created' field got set to '0000-00-00T18:00:00+01:00' rather than the creation date of the picture. I have about 2000 pictures like that so I will not be setting them manually.
I wrote a quick script in python to retrieve the Exif metadata but it seems that the 'Date Created' field is not part of Exif.
What would you recommend I do to batch update the field to the correct date? I can reference the file name which contains date/time or the Exif metadata.
I know there is an SDK, but I have no experience in Lua and no idea if it can even help me for such a job.
Thank you for any help you can provide!
If you post a question, chances are you'll figure out the answer five minutes later... as I just have.
Find the field:
$ strings 2015-03-14_15-47-43_89287.CR2|grep 'photoshop:DateCreated'
<photoshop:DateCreated>0000-00-00T18:00:00+01:00</photoshop:DateCreated>
fix it quickly:
$ time LC_ALL=C sed -i.bkup 's/0000-00-00T18:00:00+01:00/2015-03-14T15:47:43+01:00/g' 2015-03-14_15-47-43_89287.CR2
real 0m0.265s
user 0
...Copy link to clipboard
Find the field:
fix it quickly:
real 0m0.265s
user 0m0.183s
sys 0m0.042s
check it:
<photoshop:DateCreated>2015-03-14T15:47:43+01:00</photoshop:DateCreated>
You now have a backup of the original file and an updated RAW file in under a second. Wrap a basic shell script around it and you are done.
I hope this will help someone.
