Anyone have any idea how to rollback?
I really can't use this DW 2017... 2015 was almost perfect... the Find & Replace is 'broken'.. or i just don't know how to use this new version anymore. Previously replacing code in multiple files in folders was as easy as opening up DW, select Find & Replace, enter code to find and code to replace, then REPLACE. It was as simple as that.
If you have uninstalled the previous version then you can install the previous version by launching your CC APP and then under Dreamweaver look for something like this:
In the above list I have 4 different versions available for me to download and install automatically. Please make sure you choose the Advance option when you install it so that you can uncheck to uninstall the current versions on your system. You don't want to remove them unless you are short of disk space. These days HDs are v
...Copy link to clipboard
In the above list I have 4 different versions available for me to download and install automatically. Please make sure you choose the Advance option when you install it so that you can uncheck to uninstall the current versions on your system. You don't want to remove them unless you are short of disk space. These days HDs are very cheap and so space should not be a limiting factor.
If you don't see the previous versions in the APP then you may need to expand the Previous version tab as shown in this picture:
Hope this helps.
Thank you sir! You're the best!
I'm having trouble rolling back Dreamweaver 2017 to 2015. Using Windows 10. 2017 is uninstalled. The CC app doesn't have the older version dropdown that you show and immediately starts 2017 installation.
Am I going about it the wrong way?
See How to Find and Install Previous Version of Adobe Apps in CC 2015 | Adobe Customer Care Team
Thank you!
You are likely going into the wrong heading in the CC Desktop app, it happens pretty regularly because Adobe has 2 areas in the app that seem like you should be able to find a previous version within.
In the CC Desktop App there is a main heading called PREVIOUS VERSIONS. That, oddly enough, is the wrong place to go to get previous versions. That particular heading only shows you the previous versions you already have installed.
You need to click on the small blue link on the right side of the FIND ADDITIONAL APPS bar. Then select the bottom most option named VIEW PREVIOUS VERSIONS.
Doing that will populate the FIND ADDITIONAL APPS heading with programs and drop-down menu Install buttons.
Thank you!
