nasıl yapılır ? genelde siz neler yapıyorsunuz arkadaşlar sıralayabilir misiniz , teşekkürler
In general, InDesign would be used for publications, not for architectural layouts (if the Microsoft Translator is correct).
But you'd need to provide more information about what you're trying to do, and what isn't working the way your expect for us to help you. Also, what version of InDesign are you using, and what computer platform are you using?
j'avais essayé de charger mes dessins (les plans , les façades,les coupes et des dessins des intentions des shémas) sur indesign pour une bonne mise en page format de A2. Apres je vais essayer de faire ça en utilisant Photoshop mais je sais pas utiliser photoshop aussi.
Are you trying to add drawings to an InDesign document? You can use File > Place. You will likely need to save your drawing into a format recognized by InDesign. Consider exporting to a PDF.
Are you using Revit? Here's a resource:
The One About Revit to InDesign | The Architect's Digital Design Guide
Thank you very much . I learned that photoshop is more usefull than indesign for architecture .
but it's good to learn indesign too. Thanks a lot
