Is there a way to have text frame sizes adjusted in a "master-slave" relation? If I adjust the "width" of the 1st frame, I want the other to copy the "width" instantly. Is there a way to do this? Thanks
Moved out of the Forum Lounge and over to the InDesign forum.
Primary text frame could be what you're looking for.
Select this option when you create a new document then if you alter the dimensions of the frame on your master page that will resize frames throughout your document.
if the other frames
1. are on the same spread and
2. also are selected
you could use a script like the one released lately by Marc Autret:
Indiscripts :: Equalizer PRO 3.0 released!
Uwe
One more idea...
What if you just create an object style for the text frames? This works for 1 or more columns, though I am showing just one.
