I have a one page site here in staging:
When viewed on an Android 7.0 device Chrome 55.0.2883.91, and you press the burger menu, the accordion opens, then suddenly closes. On iPhone, it stays open, which is what I want it to do. It should close when someone clicks the close "x".
Hi all,
Please update to the latest version of Muse (2017.0.2) where this issue has been fixed.
Preran
It does stay open it my Android however its is 6.0.1 Chrome 54.0.2840.85 I will have to grab and check the same behavior in the 7.0 version device.
Ok yes, you are right, it looks some issue with either Android 7.0 or chrome.
I have seen that it stays open if you long press on the accordion.
We will check this out and let you know if any bug is required to be logged.
Ankush
This has just started happening for me too.
http://www.sentinelhomes.co.nz on Android chrome.
Samsung S7 Chrome 55.0.2883.91
Works fine on the Samsung browser, and desktop chrome with mobile inspector view
Any sort of easy patch or work around would be great. Not sure if I can wait for a muse update on this live site!
Ta
Thank you for the feedback. We are investigating this issue. Stay tuned for updates.
Preran
Just changed my site to use a composition widget for navigation, thinking it would fix it.
It doesn't.
Looks like the issue is that the tap is somehow being treated as two taps, and its opening and closing because it thinks its getting two taps.
Please can someone write a bit of JS we can put in the head that temporarily fixes this?
Can confirm that its making two taps.. If i move the close button away from the trigger, it works ok. But if the trigger is also set to close, or if the close button is on-top of the trigger, it opens and closes without staying open.
Any work arounds yet Adobe? This is a critical issue. It could have wrecked thousands of sites! Preran
The same problems. Problem with all android. And with all browser.
Came looking for this problem.
My existing properties that were made with Muse all have this problem on Android as of a sudden.
Let me know when a fix is available.
I am having the same issue.
All of my sites that use the accordion are not functioning correctly in Chrome for Android (version 55.0.2883.91).
Have been furiously switching them out, but am finding it very difficult to acquire a replacement. This is very troubling since all of my sites are Muse based.
Hello Everyone,
We regret the inconvenience caused and assure you all that the fix will be available in the next update till then could you please try the workaround mentioned in this doc - Accordion widgets collapses when viewed on Android OS and let us know if it works for you?
Ankush
The above fix doesn't work. It just breaks it on the iPhone. I tried the Accordion widgets collapses when viewed on Android OSa exactly and it breaks on iPhone.
Basically, it leaves the menu open on iPhone and won't let you close if you unselect "Can Collapse All".
I am sorry to hear that it did not work for you. The team is working on a fix, and it will be available in a future update. Stay tuned.
Preran
Hi all,
The team has shared with us a temporary fix until an update with this fix is released. Please try it and let us know if it helped.
Preran
Hi Preran:
This seems to break on the iPhone. I touch the "hamburg" and it doesn't do anything. When I touch it three times, it finally opens.
Welcome to Hudson Small Engine
Let me know if you want my source file.
Can I get a free month of Adobe Creative Cloud for finding this bug?
I am not sure about the free sub, but I will check with the team about the iPhone issue to see if they can reproduce it.
Preran
Any luck solving this? I can't figure out what the cause is for the life of me
This issue has been resolved. Please try the solution by Preran, which is marked as correct.
Well, other users say that it messes up on iPhone if you use that fix, which is not an option for me. I will try it myself and report back.
The issue is still not fixed - are there any updates? It's been a month since the last reply
While the issue still exists, the hotfix provided by Preran above worked for me. Its a pain but at least my clients are happy for now
Cave pirate:
Did you test it on the iPhone? The fix broke on my iPhone when I tried it.
Hi:
So, the new fix seems to work somewhat. However, now I have to click around the hamburg/close button to get it to work. I can't click directly on it. This is both on the iPhone and newest Andriod. It works fine on the desktop.
Hi all,
Preran
