I have been trying unsuccessfully to change this command to a wild card statement for files in this folder... I may be mixing two different scripting styles together but not sure... Creating a Hot folder that will grab files as they are placed in folder... Have it working successfully when I use a generic file.opendialog option but want it to grab the file from the folder...
Help Please...
//This is just the place portion of my entire script...
//Place New Image
var image = File('~/Desktop/Files/*.*');
var newimage = docRef.placedItems.add();
newimage.file = image;
newimage.position = [200,-300];
Declaring a File instance imply to specifically path an url to a File whatever it exists or not at the time.
You can't use such a shortcut for getting any files of the folder. Instead you may want to use Folder.getFiles()
...//Place New Image
var fo = Folder ( '~/Desktop/Files' );
var files = fo.getFiles ( /* you may want to use a filter function here. See doc */ );
var file, newimage;
while ( file = files.pop() ) {
newimage.file = file;
//Place New Image
var file, newimage;
HTH
Loic
