Hello,
I have multiple documents, different sizes and/or color modes, that all have the same links. Is there a way to update a link across all open documents? Using Latest cloud (17 i think?)
thanks!
thank you for your Quick reply!
will this work if the filenames are different? that is the root of my problem, which i regretfully omitted form the original post.
"that all have the same links"
And how the program can tell if the link is 'the same'? Right, because it has identical name...
You omitted the root of your question, I'm afraid...
If the only difference is file extension, then it can be relinked via UI and maybe - scripted.
You better ask in scripting forum, then.
sorry about that, thank you for your help!
I also wrote a script for batch relinking images whose basic names are the same, but extensions are different -- Update path names in links.
— Kas
