Clipping mask with Illustrator group?
Engaged ,
Dec 13, 2016 Dec 13, 2016
I have artwork I created in Illustrator that is made out of 3 objects.
I have a photo.
I want to use the artwork I created in Illustrator as a clipping mask in InDesign for the photo and I want the photo to span the three objects in the group. I can't get this to work.
Try 1:
1. Import Illustrator art
2. Import photo
3. Cut photo
4. Select Illustrator art
5. Select Paste Into
Result: InDesign pastes the photo into the rectangle boundary that the Illustrator is inside, so I end up with a rectangle mask instead of the Illustrator shape.
Try 2:
1. Copy and paste the shape from Illustrator into InDesign
2. Import the photo
3. Cut the photo
4. Select the pasted Illustrator shape
Result: It only made 1 of the 3 shapes that make up the artwork a clipping mask, not all three. It needs to span all three shapes.
This can't be hard. I've seen people do this kind of thing in brochures a million times. What am I missing here?
Thank you so much!
14.0K
Community Expert , Dec 13, 2016 Dec 13, 2016
In InDesign, select the 3 shape objects and make them Object > Paths > Make Compound Path.
Now that the 3 are a compound path, you can Paste Into.
Mike Witherell
Engaged ,
Ahhhh!! Thank you!
This didn't work at first. I had to paste from Illustrator and then select Object>Paths>Open Path and THEN I could select Make Compound Path.
Thank you so much, Michael. Have a great day.
Dec 04, 2019 Dec 04, 2019
Why can't we do that in Illustrator?
Dec 12, 2019 Dec 12, 2019
You can (I'm using Adobe Illustrator 2020 on Windows)
Select the objects > Right click > Make compound path
Or
Select the objects > Object > Compound path > Make (Ctrl + 8 by default)
