Hey guys! I'm having an issue trying to rename the panes in my project in Robohelp 9. I have the project itself renamed (as you can see in the top left)... I finally figured out how to rename the window that is output in the .chm (Project Set-up > Local Window > Properties), but I still have all these panes in the project with the wrong name. Does anyone know how to update those?
Thanks in advance!
Hi there
Perhaps try this.
Close the TOC, Index, and Glossary pods.
From the Project Manager pod, expand each of these sections.
Try Right-Clicking each of them and choosing Rename.
Give that a go and see if it helps you achieve your goal.
Cheers... Rick
What's "the wrong name"? You've just got the Starter tab open on the right, so that's what's giving the top window its name of ProjectName - [Starter]; the other tabs are because you've got the ToC, Index & Glossaries open & it's the default one (you can have more than one in existence - RH needs to know which one is going to be used as the default one).
I didn't realize I could have multiple. Thanks!
Hi there
Perhaps try this.
Cheers... Rick
Duuuuuude.... That was embarrassingly easy. smh....
Thanks a lot Rick!!
