4 Replies Latest reply on Dec 20, 2016 10:04 PM by johnrellis
    importeren gps-gegevens lukt niet
    janz54272868
      Als ik de foto's van de kaart importeer in lightroom (versie 6), komen de gps-data niet mee, terwijl ik ze op de camera wel kan bekijken. Ik heb de optie "alles" geselecteerd bij het importeren van de metadata, dus ook de gps-gegevens. In het verleden heb ik hier nooit problemen mee gehad, wat is er aan de hand ????
        • 1. Re: importeren gps-gegevens lukt niet
          johnrellis Most Valuable Participant
          Translation: If I use the pictures from the card import in lightroom (version 6), the gps-data not with it, while I can view them on the camera though. I have the option "all" selected when importing the metadata, including the gps data. In the past, I've never had problems with it, what is going on????
          In the Apply During Import panel of the Import window, set Metadata to "None":
          If the problem no longer occurs, then you had a Metadata preset that is clearing the GPS data (and if you can't figure out how to edit the preset to stop that, ask here).
          If the problem still occurs, then upload to Dropbox (or similar) a sample photo taken directly from the card using Finder or File Explorer (i.e. a file that's never been imported to LR).  Post the sharing link here, and we can take a look to see if the photo's GPS metadata is compatible with LR.
          • 2. Re: importeren gps-gegevens lukt niet
            janz54272868 Level 1
            Sorry for the time it took to give you an answer. When I set metadata on none, as you advised the problem is solved. Can I use the preset also in the future or do I have to chance the preset of metadata. In the last case, could you tell me how I can change the preset  ???
            • 3. Re: importeren gps-gegevens lukt niet
              Hello John,
              Thanks for your reaction, it was very helpful. Sorry for the time it took to give you an answer. When I set metadata on none, as you advised the problem is solved. Can I use the preset also in the future or do I have to chance the preset of metadata. In the last case, could you tell me how I can change the preset  ???
              Greetings
              Jan Zanders
              Op 13 dec. 2016, om 19:43 heeft johnrellis <forums_noreply@adobe.com> het volgende geschreven:
              View the full discussion <https://forums.adobe.com/message/9199923#9199923>
              • 4. Re: importeren gps-gegevens lukt niet
                In the Apply During Import panel, select Edit Presets:
                Then in the edit window, select your preset and make sure the box to the right of GPS is unchecked:
