How do make the text to wrap -in the text fields- when i create an interactive pdf form using Indesign CS6?
You can tick Multiline in the Buttons and Form dialogue box in InDesign, and you can also do it in Acrobat. (You have to set the size of the text box to be large enough for more than one line!)
Thanks Derek, my i also ask (cause u seem to be "the guru" 🙂 ) how do i center text on the text field? All text seems to be positioned left, in my case i want to be able to align it center, is it possible?
In Acrobat, within Form editing, double-click a form field to get to Text Field properties; go to the 4th tab called Options; and the first drop-down box is Alignment where you can choose Center.
Also, if you don't like post-production fixes in Acrobat, there is
FormMagic – Id-Extras: InDesign Scripts, Tips & Solutions
and related to it
These plugins help fill in the shortcomings of InDesign's form field generation.
So IndesignCS6 alone does not have the ability to fix this issue?
No, it doesn't.
