How to avoid wrap in find method ?
Dec 14, 2016 Dec 14, 2016
Dear friends,
Although i carefully followed the advice found at this post, I have no success. The find always wraps back to the first occurrence fo the items to be found.
Case 3 works fine for several months now - but why does case 4 not?
Jang obviously had the same problem in the mentioned post ...
function GetFindParameters (iType, sSearch) {
var propVal, findParams = new PropVals() ;
  switch (iType) {
    case 3: // ---------------------------------- find marker of type sSearch, don't wrap
      propVal = new PropVal() ;
      propVal.propIdent.num = Constants.FS_FindWrap ;
      propVal.propVal.valType = Constants.FT_Integer;
      propVal.propVal.ival = 0 ;
      findParams.push(propVal);
      propVal.propIdent.num = Constants.FS_FindMarkerOfType;
      propVal.propVal.valType = Constants.FT_String;
      propVal.propVal.sval = sSearch;
      return findParams;
      break;
    case 4: // ---------------------------------- find character format sSearch, don't wrap
      propVal.propIdent.num = Constants.FS_FindCharTag;
      propVal.propVal.valType = Constants.FO_CharFmt;
      return findParams;
      break;
    default:
      alert ("GetFindParameters:\nPgm error: case " + iType + " in switch not defined.", "GetFindParameters", true);
      return null;
} //---  end GetFindParameters
Because of this my searches are not terminated and loop forever - FA_errno is not set (as described in the FDK doc).
  findRange = goCurrentDoc.Find  (oTextLoc, findParams);// finds text range (object pgf), lenght 1
  if (FA_errno === Constants.FE_NotFound) {
    return null;                                  // no further items
What's wrong with my search parameters?
Scripting
469
Enthusiast , Dec 14, 2016 Dec 14, 2016
Hi Klaus,
in case 4 you are overriding "propVal.propVal.valType" (line 21) with line 25.
I think you forgot "propVal = new PropVal() ; " Insert after line 23
Enthusiast ,
Hi Klaus,
As usual: to close to the screen the overview is lost...
Thank You, Klaus!
