I'm attempting to create a list like this:
1 Level 1
1.1 Level 2
1.2 Level 2
1.3 Level 2
2 Level 1
2.1 Level 2
2.1.1 Level 3
2.1.2 Level 3
2.1.3 Level 3
However, this is happening:
Whatever I try, level 3 restarts at 1, so for example I get 1.1.1 instead of 2.2.1.
I'm using three numbered list paragraph styles as follows:
Level 1:
Level 2:
Level 3:
I'm utterly confused why this isn't working.
Can anyone suggest what's going wrong?
Your third screenshot shows that your Level 3 points to a *different* list. Make it the same list as the other two (in your case, choose Level 2 - Multi-level.)
When you make a different custom named LIST, you are instructing InDesign to number differently and independently of your current list pattern.
Michael, thank you!! Seems so obvious now you say it.
Hi all! I know this post is old but I'm hoping someone can let me know how to fix the issue I'm having. So currently, I have the same bullet structure as what's listed above, and my screenshots match as well, and my bullets are part of the same list "multi-list." The only difference is, I started my bullets at level 2...so my first level is not 1., it starts at 1.1. In my example below, I'm going to jump to the 3 because that's where I started running into issues.
3.1 - Level 1
3.2- Level 2
3.2.1 - Level 3.
This was working great until I got to a section where the intro is 3.1, and the next number following is 3.1.1 Does anyone know how to set it up so it goes from 3.1 to 3.1.1 ? I'm assuming it's because I'm trying to jump from level one to level 3 with the bullets?
