Below is a script which will take each cell in the first column of a table and merge it with the cell on the right. It assumes the cursor is in one of the cells on the right.
I am trying to upgrade this so that if the cursor is placed in any cell in the table (except in the last column), then the script is run, it will merge each cell in the column of the cursor with the cell on the right. I assume there are no prior merges in the table.
Set myInDesign = CreateObject("InDesign.Application")
If myInDesign.Documents.Count <> 0 Then
Set myDocument = myInDesign.Documents.Item(1)
If myInDesign.Selection.Count <> 0 Then
myResponse = MsgBox("Is an insertion point in column one of the table?", vbYesNo)
If myResponse = 6 Then
If TypeName(myInDesign.Selection.Item(1).Parent) = "Cell" Then
Set myCell = myInDesign.Selection.Item(1).Parent
Set myColumn = myCell.ParentColumn
Set myTable = myInDesign.Selection.Item(1).Parent.Parent
' Set myColumNumber = MyTable.myColumn.Item
For myCounter = 1 to myColumn.Cells.Count
myTable.Rows.Item(myCounter).Cells.Item(1).Merge myTable.Rows.Item(myCounter).Cells.Item(2)
Next
MsgBox ("Done")
End If
Else MsgBox ("Place insertion point correctly and restart script")
End If
End If
End If
Thank you Trevor. I now have a working script.
Hi M F
This is from the SDK
Set myStory = myDocument.Stories.Item(1)
Set myTable = myStory.Tables.Item(1)
Rem Merge all of the cells in the first column.
myTable.Cells.Item(1).Merge myTable.Columns.Item(1).Cells.Item(-1)
Rem Convert column 2 into 2 cells (rather than 4).
myTable.Columns.Item(2).Cells.Item(-1).Merge myTable.Columns.Item(2).Cells.Item(-2)
myTable.Columns.Item(2).Cells.Item(1).Merge myTable.Columns.Item(2).Cells.Item(2)
Rem Merge the last two cells in row 1.
myTable.Rows.Item(1).Cells.Item(-1).Merge myTable.Rows.Item(1).Cells.Item(-1)
Rem Merge the last two cells in row 3.
myTable.Rows.Item(3).Cells.Item(-2).Merge myTable.Rows.Item(3).Cells.Item(-1)
HTH
Trevor
Trevor, I have already seen this, and used part of it in the script I submitted. I am still trying to find how to identify the column in which the cursor is displayed.
Hello Again
This will Do what you want. Sorry about my above stupidity.
' Absolutely Zero Error Checking
' Will Hopefully merge selected cells
' This will only Work if text or insertion point of a cell isselected :-;
Set myInDesign = CreateObject("InDesign.Application.CC.2015")
Set mySelection = myInDesign.Selection.Item(1)
Set MyCell = mySelection.Parent
Set MyCellsRow = MyCell.ParentRow
Set MyCellsColumn = MyCell.ParentColumn
Set MyCellsRowsLastCell = MyCell.ParentRow.Cells.Item(-1)
If MyCellsRowsLastCell <> MyCell Then
MyCellsColumn = CInt(MyCellsColumn) ' Change to Int for Index reference
MyCell.Merge MyCellsRow.Cells.Item(MyCellsColumn + 1)
End If
To Merge selected cell do
' This will only Work if cells are selected :-;
Set MyCells = mySelection.Cells
Set firstCell = MyCells.Item(1)
Set lastCell = MyCells.Item(-1)
firstCell.Merge lastCell
' In JavaScript which is a much more civilized language one could do
' app.selection[0].cells[0].merge(app.selection[0].cells[-1]);
' Which is the vbs equivalent of
' myInDesign.Selection.Item(1).Cells.Item(1).Merge myInDesign.Selection.Item(1).Cells.Item(-1)
HTH
Trevor
P.s.
You should note that it's not a good idea to script InDesign with Visual Basic (Script) unless you have good reason to.
JavaScript is much more recommended
if answer 3 is the correct answer, give that one the "Correct Answer" label and not your comment on the correct answer.
If answer 3 is not the correct one and you figured out yourself what the correct code is, please post that code and make it the "Correct Answer".
Uwe
Hello M F Walker
4 is a correct answer.
It is correct to say thank you.
3 is the correct answer as it answers the question
Both scripts work.
The 1st one will merge the cell with selected text with the cell to the right of it.
The 2nd one merges all selected cells.
Please mark 3 as correct.
Ta very much.
Trevor
