Metadata förs ej över från biblioteksmodulen till framkallamodulen
Dec 16, 2016 Dec 16, 2016
Hej! Jag har en Nikon D 5300 och all info om objektiv och bild finns i biblioteks-modulen. När jag går över till framkalla-modulen och vill göra objektivkorrigering så finns inte objektivprofilen där. Vid försök att lägga in objektivet manuellt är problemet att då har man bara 8 objektiv att välja på. Vad gör jag för fel?
365
Community Expert , Dec 16, 2016 Dec 16, 2016
Are you shooting jpg?
Most lens profiles are for RAW files only. For jpgs, the lens correction is usually done in the camera.
I have both JPEG photos (old photos) and also all new photos that is in Raw-format. The metadata is not transmitted to the develop module in any case.
Is the lens you use supported?
See a list of supported lenses (for profiles) here: Supported lenses
Also, the lens info you see under Metadata in Library is not the same thing as a lens profile.
The lens info in the Metadata panel  is recorded by the camera when you take the picture - but a lens profile is something entirely different - it is a file on your computer and part of the Lightroom installation.
If there isn't a profile for your lens, then either Adobe hasn't made a profile for it, or you are using an older Lightroom version that doesn't include that profile.
Dec 17, 2016 Dec 17, 2016
I have three lenses for my camera. All three (Nikon AF-S DX Nikkor 35mm
f/1.8 G, Nikon AF-S Nikkor 18-55 mm f3.5-5.6 G VR II, AF-S Nikkor 55-300mm
f/4.5-5.6 GED VR) are listed as supported. I am subscribing on Creative
Cloud and Lightroom is 2015 CC. I had to reset my computer recently and I
can´t read out which version I got but I believe it is Version 2015.6 or 8.
I was born at the time when dinosaurs still was living on earth and
although I have used computers at work from the time when punch cards was
in use until today, I have never been able to get any education in use of
digital equipment so probably I have made some mistakes when downloading or
use of the Lightroom.
2016-12-16 20:42 GMT+01:00 Per Berntsen <forums_noreply@adobe.com>:
Metadata förs ej över från biblioteksmodulen till framkallamodulen created
by Per Berntsen <https://forums.adobe.com/people/Per+Berntsen> in *Photoshop
Lightroom* - View the full discussion
<https://forums.adobe.com/message/9207737#9207737>
Dec 19, 2016 Dec 19, 2016
The problem is solved. Looking at the pictures I found that the camera was saving in JPG:s after I got the camera back from Nikon after adjustment, although it was noted in the menu "sparar i RAW". The cameras configuration was the same as when sold. In the menu I could only change from 12 to 14 bits and thats why the texts shows "sparar i RAW". The change from JPG to RAW is made in the info system and after doing so everything is working beautifully.
