Hej! Jag har en Nikon D 5300 och all info om objektiv och bild finns i biblioteks-modulen. När jag går över till framkalla-modulen och vill göra objektivkorrigering så finns inte objektivprofilen där. Vid försök att lägga in objektivet manuellt är problemet att då har man bara 8 objektiv att välja på. Vad gör jag för fel?
Are you shooting jpg?
Most lens profiles are for RAW files only. For jpgs, the lens correction is usually done in the camera.
I have both JPEG photos (old photos) and also all new photos that is in Raw-format. The metadata is not transmitted to the develop module in any case.
Is the lens you use supported?
See a list of supported lenses (for profiles) here: Supported lenses
Also, the lens info you see under Metadata in Library is not the same thing as a lens profile.
The lens info in the Metadata panel is recorded by the camera when you take the picture - but a lens profile is something entirely different - it is a file on your computer and part of the Lightroom installation.
If there isn't a profile for your lens, then either Adobe hasn't made a profile for it, or you are using an older Lightroom version that doesn't include that profile.
I have three lenses for my camera. All three (Nikon AF-S DX Nikkor 35mm
f/1.8 G, Nikon AF-S Nikkor 18-55 mm f3.5-5.6 G VR II, AF-S Nikkor 55-300mm
f/4.5-5.6 GED VR) are listed as supported. I am subscribing on Creative
Cloud and Lightroom is 2015 CC. I had to reset my computer recently and I
can´t read out which version I got but I believe it is Version 2015.6 or 8.
I was born at the time when dinosaurs still was living on earth and
although I have used computers at work from the time when punch cards was
in use until today, I have never been able to get any education in use of
digital equipment so probably I have made some mistakes when downloading or
use of the Lightroom.
2016-12-16 20:42 GMT+01:00 Per Berntsen <forums_noreply@adobe.com>:
Metadata förs ej över från biblioteksmodulen till framkallamodulen created
by Per Berntsen <https://forums.adobe.com/people/Per+Berntsen> in *Photoshop
Lightroom* - View the full discussion
<https://forums.adobe.com/message/9207737#9207737>
The problem is solved. Looking at the pictures I found that the camera was saving in JPG:s after I got the camera back from Nikon after adjustment, although it was noted in the menu "sparar i RAW". The cameras configuration was the same as when sold. In the menu I could only change from 12 to 14 bits and thats why the texts shows "sparar i RAW". The change from JPG to RAW is made in the info system and after doing so everything is working beautifully.
