Illustrator JPEGExportOptions Object properties are missing in Object Model
Dec 16, 2016 Dec 16, 2016
The Adobe Illustrator JPEGExportOptions Object properties are missing or mismatched in Object Model? Please advice.
Scripting
1.5K
Community Expert , Dec 16, 2016 Dec 16, 2016
Why don't you use action with Javascript like below?
function exportJPG(pth){ //Export 300dpi CMYK jpg
  var str = "";
  for (var i=0;i<pth.length;i++) str += u16to8(pth.charCodeAt(i));
  var act = "/version 3/name [ 4 73657431]/isOpen 1"
  + "/actionCount 1/action-1 {/name [ 4 61637431]/keyIndex 0/colorIndex 0/isOpen 1/eventCount 1"
  + "/event-1 {/useRulersIn1stQuadrant 0/internalName (adobe_exportDocument)"
  + "/isOpen 0/isOn 1/hasDialog 1/showDialog 0/parameterCount 7"
  + "/parameter-1 {/key 18854
Adobe
Engaged ,
What features do you need? Specifically.
There are workarounds – through Photoshop...
The object properties and actual Illustrator JPEG Export Options are not equal, that is my problem, see the attached both screenshots, and i could not fix my scripting.
Example:
Image Color Model = CMYK,
Options [Compression Method, Resolutions, and etc.,]
  var str = "";
  + "/parameter-1 {/key 1885434477/showInPalette 0/type (raw)"
  + "/value < 100 0a00000001000000030000000100000000002c01020000000000000001000000"
  + "69006d006100670065006d006100700000000000000000000000000000000000"
  + "0000000000000000000000000000000000000000000000000000000000000000"
  + "00000100>/size 100}" //Probably, parameter for exporter plugin
  + "/parameter-2 {/key 1851878757/showInPalette 4294967295"
  + "/type (ustring)/value [ " + str.length/2 + " " + str + "]}"
  + "/parameter-3 {/key 1718775156/showInPalette 4294967295"
  + "/type (ustring)/value [ 16 4a5045472066696c6520666f726d6174]}" // JPEG file format
  + "/parameter-4 {/key 1702392942/showInPalette 4294967295"
  + "/type (ustring)/value [ 12 6a70672c6a70652c6a706567]}" //jpg,jpe,jpeg
  + "/parameter-5 {/key 1936548194/showInPalette 4294967295/type (boolean)/value 0}"
  + "/parameter-6 {/key 1935764588/showInPalette 4294967295/type (boolean)/value 1}"
  + "/parameter-7 {/key 1936875886/showInPalette 4294967295/type (ustring)/value [ 0]}}}";
  var tmp = File(Folder.desktop + "/set1.aia");
  tmp.open('w');
  tmp.write(act);
  tmp.close();
  app.loadAction(tmp);
  app.doScript("act1", "set1", false);
  app.unloadAction("set1","");
  tmp.remove();
function u16to8(cd) {
  var out =
  (cd < 0x80
  ? toHex2(cd)
  : (cd < 0x800
  ? toHex2(cd >> 6 & 0x1f | 0xc0)
  : toHex2(cd >> 12 | 0xe0) +
  toHex2(cd >> 6 & 0x3f | 0x80)
  ) + toHex2(cd & 0x3f | 0x80)
  return out;
function toHex2(num) {
  var out = '0' + num.toString(16);
  return out.slice(-2);
var pth = Folder.selectDialog("target Folder?").fsName + "/test.jpg";
exportJPG(pth);
Dec 25, 2016 Dec 25, 2016
Thank you,
I will go with actions with JS.
