I was using Stabilize Motion. I closed the Tracking Panel by accident. When I reopened it, the option to analyze frames disappeared. I can't get it back. How do I resume tracking?
Enable the "Show Options" setting in the flyout menu.
I am not sure what you mean exactly, where is "show options". care to demonstrate?
it's not your fault but the interface's faulty U.I design which has made many users puzzle over "where's the rest of my panel" question. Motion Tracker in AE CC 2017
where's the rest?
click on the panel to see the bor
...Copy link to clipboard
Mylenium
where's the rest?
click on the panel to see the borders (your case is easier because you already saw the borders)
now drag the lower border down like this
to avoid this type of scenarios you can:
1. right click on any panel you want to see in the classic U.I and uncheck stacked panels group under panel group settings
2. work in the standard workspace (like I do)
3. when tracking, work in the motion tracking workspace (the panel will have a lot of room there and won't be narrowed down)
@Roei Tzoref, Your answer is correct, sir!
In this forum, with an incorrect answer, how do I label unlabel it as correct? And how do I label the correct one as correct?
What! you let Mylenium steal my thunder???
you have this at the bottom of the response text field if you marked it as the correct response
click it and mark the right one
Maybe Mylenium marked it as correct himself?
he's been known to do that here
just kidding! he can't only Op can mark response as correct otherwise it would be a whole mess in here
if you unmark his comment as correct, now leave it! now scrool down and go to my genius comment and mark it as correct
Roei Tzoref​:​
Finally!
I had to leave "Correct Answer" showing on his response...
...then scroll down to yours. The "Correct Answer" option was then available for yours...
...and I was able to click on it!
interesting! Justice has been here today thanks to your efforts Sir!
