Good day! I should windows. Ligntroom ceased to create catalog backups. He writes a warning. The cache is cleared, I tried to restart several times, and so have a second to create a directory. Other drives for backups also tried
What does the error message say? Please quote it word-for-word (and translate it to English if you can).
The permissions in your operating system must be changed. The folder where you are trying to store the backups in must have write permission.
But I did not change anything in the operating system settings. Everything worked. Probably it is necessary to reinstall Lightroom?
Did Windows get updated recently? Windows is becoming like Apple Mac. With every new update that is released it seems to change the permission setting on folders. So until you check the permissions on the actual folder and the top level folder or even the drive for the proper permissions you can't be sure they haven't changed.
In other words, you have not checked the permissions. You need to do this because sometimes things change accidentally or get changed during software updates. Reinstalling Lightroom will not fix permissions problems.
папки все в порядке
