Try to open my Lightroom this morning, which worked last week perfectly and get the "Error 16".
Searching for resolution I found the following and tried it
(a) Restore permission on license folder ( Library/ApplicationSupport/Adobe/SLStore and Library/Application Support/Adobe/Adobe PCD)
==> this didn't work
(b) I de-installed and installed the product (=> this didn't work)
(c) I tried to start LR with a user account with ADMIN rights - Here the software works, but this is not a permanent solution as I don't want to work with ADMIN rights
(d) Found a shell script to remove ACL "LightroomCorrectPermission" - I ran this script ... didn't help
Does anybody has a resolution for that??
I have the same issue. I followed this thread, getting Error: 16 after installing and trying to start , that suggested I give my specific account ID read/write permission to /Library/ApplicationSupport/Adobe/, that the Lightroom would run fine. It does fix the problem. However, that makes absolutely no sense on a Mac. Apps are installed globally. There is no need to set user specific permissions. Something is broken.
However, that makes absolutely no sense. Apps are installed globally for ALL use
...Copy link to clipboard
However, that makes absolutely no sense. Apps are installed globally for ALL users. There is no need to set user specific permissions. Something is broken.
Thanks a lot - I was already desperate.
Your tip really fixed it - I can access my LR now without ADMIN rights. I and totally agree with you, that this doesn't fit to my idea how the security system on Mac is working.
Nevertheless .... Thanks again
