Please can someone tell me how to make the Listening plug-in work? I use Photoshop CS6 run on Windows 7. I have (several times) downloaded and installed the plug-in exactly as on Adobe web-page. When I run PS, there are no log-in files on the Desktop nor anywhere else. I need the VB log-i n files, which I have used extensively with previous versions. How can I check that the plug-in is actually being recognized by Photoshop? Thanks
Help > System Info should list all of your installed plugins, such as “ScriptListener 12.0” and “ScriptingListener.plugin” (taken from CS5 on Mac).
..\Adobe Photoshop CS5\Plug-Ins\Automate
Thank you very much for your help. Help > System Info does not list a "Listener" Plug-in at all. It also identifies
Required Plug-ins folder: C:\Program Files (x86)\Adobe\Adobe Photoshop CS6\Required\
Primary Plug-ins folder: C:\Program Files (x86)\Adobe\Adobe Photoshop CS6\Plug-ins\
Additional Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Plug-ins\Automate\
I have tried putting the listening plug-in (ScriptListener.8li) into each of these, but none of this made any difference. It seems clear that Photoshop is not loading the plug-in at all, which is why I cannot find the log files. Is it the right plug-in? I got it from the Adobe web-site. Is there some setting in Photoshop that does not let me load it??
This is driving me bonkers.
Tony
Bonjour
My batch :
xcopy /y "C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Scripting\Utilities\*istener.8li" "C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Plug-ins\Automate\"
rem del "C:\ProgramFiles\Adobe\Adobe Photoshop CS6 (64 Bit)\Plug-ins\Automate\*istener.8li"
Merci
Thank you
Your batch does what I have been doing manually. There is still no sign of the plug-in in Photoshop. Help>System Info does not show it. The only mention of Scripting is that Help>System Info lists ScriptUIFlex.dll and ScriptingSupport 13.0. When I do anything in Photoshop, no log file appears on my desktop. When I have searched the whole C:\ drive, no log file can be found.
I think that ScriptListener.8li is not being recognized nor loaded by Photoshop. I do not know why - is there some option I need to change in Photoshop? Is this the correct Listener plug-in? Is the "...Plug-Ins\Automate\" the correct directory to put the plug-in? In Photoshop should I be doing something to activate the Listening or to terminate it so that it is recorded or to identify the directory where the log files should go? Etc., etc.
Arrrrrgghh
Thank you for your help
Tony
I experienced same problem. I tried to copy ScriptListener.8li file from some previous version of Photoshop. It didin't create ScriptingListener.log on my desktop. I tried to put then ScriptListener.8li to all possible folders Photoshop should detect it in. It won't help too, so I googled for "ScriptListener.8li CS6" and clicked first link (right now tried too). There I found appropiate file to CS6. All what didn't work just started working!
ScriptListener missing from Photoshop CS6This plug-in was installed with…
I remember somone on this forum got same problem and JJMack provided the same site.
Thank you for all of your help. I discovered that (unknown to me) someone had installed Photoshop 32 bit in addition to the correct installation of the 64-bit version I use. They changed my short-cut, so I was launching the 32 bit version, but had never put the plug-in there because I did not know it existed!!
Everything now does what it is supposed to do.
Thank you
Happy Christmas
Tony
Bonjour
May be
An authorization problem (UAC)?
Thank you. As you can see from my previous post, the problem was to do with having the 32 and the 64-bit versions installed on my computer.
This is now solved.
Tony
