3
How to create a simple bobbing up and down motion expression?
Engaged ,
Mar 18, 2013 Mar 18, 2013
Hi, I have a 3D object that I want to continuously bob up and down but I'm having trouble finding an expression to do this.
I would use wiggle on the Z except wiggle creates random motion and I need consistant up and down oscillations.
It seems simple but I can't figure it out... any ideas? Thanks.
-Pete
Expressions , How to
73.7K
Try this:
amp = 100;
freq = 1;
y = amp*Math.sin(time*freq*Math.PI*2);
value + [0,y,0]
Dan
Engaged ,
Wow Dan, that works perfectly... thanks for the help!
It would be cool if wiggle had an option to control the randomness so I can get the same results as your expression.
-Pete
Dec 19, 2016 Dec 19, 2016
Hi Dan,
Please can you tell me which wiggle preset you use?
Many thanks,
Lisa
I'm not sure what you mean. I don't use a wiggle preset.
Dan
Jun 02, 2017 Jun 02, 2017
Hi Dan - your solution is a lifesaver. Pretty new still to a Position Express - if I wanted to do a horizontal shake back and forth rather than up and down like your code, what would that look like? I tried subbing in X for Y values but that didn't work. Much appreciated!
Julie
This should work:
amp = 100;
freq = 1;
x = amp*Math.sin(time*freq*Math.PI*2);
value + [x,0,0]
Dan
Amazing, it worked! thank you Dan!
Oct 07, 2018 Oct 07, 2018
Hi, Dan -
How exactly are you designating x and y as targets for the expression?  I understand x = or y = _____, but I am getting lost when you write things like [0,x,0] and so forth.  I think arrays when I see [ ], but I don't understand what the arguments are inside those brackets.
For instance, say I wanted to oscillate on both the y and z axis'?  What about cos on y and sin on z?
Many thanks!
Billy B
Oh wait I think I got it...  Inside of the brackets goes the arguments for the x y and z.  So it's ...
value + [x,y,z]
Here's the code you gave modified to oscillate on the y axis by sin and the z axis by cosine.
ampY = 10;
ampZ = 10;
freqY = 1;
freqZ = 1;
y = ampY*Math.sin(time*freqY*Math.PI*2);
z = ampZ*Math.cos(time*freqZ*Math.PI*2);
value + [0,y,z]
This post really helped a lot!!  Seems like the folks who write the how-to's on the Adobe website are engineers and can't think like a doofus (like me LOL).
Cheers!
BB
Jul 31, 2017 Jul 31, 2017
Hey Dan I am kind of new to after effects and I understand expressions but I honestly not sure where you post these lines. Can you help out? Would be much appreciated.
These are Position expressions. Is that what you meant?
Dan
Yes that was! Thank you so much! How can I get this to start at a specific time?
Aug 01, 2017 Aug 01, 2017
try subbing this for the last line of Dan's expression.
t=time; // Comp Time //
StartTime=2; // time in seconds | change this to when you want it to start //
if (t < StartTime) value else (value + [x,0,0])
so that the end result is:
amp = 100;
freq = 1;
Thanks a ton for the help! How do I format the time that I need to enter? I'm still new to expressions.
This is what my expression lines look like but it starts at the beginning still.
amp = 15;
freq = 1;
StartTime=2;                      // 07:45 //
if (t < StartTime) value else (value + [0,y,0])
Aug 02, 2017 Aug 02, 2017
Future reference  anything inside of forward slashes in expressions are just comments. By using a double slash, that means that section of text, etc are not "seen"by the software.
I highly recommend doing the JavaScript course on CodeCademy's website, it's free and very helpful for first time coders. It's not a direct application to AfterEffects, but most of the information like setting up variables and using if, or, else statements hold true.
To adjust the StartTime, change the "2" to whatever time you want in seconds.
Based on your reference above ^ you want it to start at 7 minutes and 45 seconds. This would be 465 seconds, so...
amp = 15;
freq = 1;
StartTime=465;                      // Start Time of Bobbing effect //
Aug 15, 2017 Aug 15, 2017
How do I do the same thing but for rotation?
Instead of setting up for an [X, Y] coordinate, you use the same expression but for a single number ouput.
amp = 15;
freq = 1;
R = amp*Math.sin(time*freq*Math.PI*2);
if (t < StartTime) value else (value + )
Jun 28, 2019 Jun 28, 2019
Dan you mad man that is incredible
Jul 10, 2019 Jul 10, 2019
thanks a ton for this script Dan,
I wonder if there would be a way to add a time interpolation to this expression, so that it animates every other frame - on twos or in threes for example which is very useful for animation techniques.
something like
tStep = framesToTime(x);
where x would be how many frames it holds before advancing to the next interpolation? hope it makes sense?
You could start the expression with this to set the frame rate:
posterizeTime(15)
Dan
great, simple and effective. Thanks!
Jul 13, 2019 Jul 13, 2019
Dan you After effects legend, is there possibly a way to reduce the distance of the bobbing? so it's a little softer. The expression is perfect but it bobs too far, from the bottom of my composition to the top!
Just change the value of the amp variable to something smaller.
Dan
Jul 03, 2020 Jul 03, 2020
Hey Dan,
I'm currently using this expression for a small project I'm working on, it works amazingly, but I need help with an adjoining element. I'm attempting to add a circular shadow underneath the object I have floating using your expression, but I'm wondering if it's possible to have the shadow underneath expanding and contracting in the same tempo and style as the object above it, does this make sense to you at all?
Best,
Myles
